Yes. A wrong number T'Con can cause this. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
If you can see the Logo; the back light is there. Contact any service technician; Sounds like main board fault. In most cases, a firmware update might help you. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
ShopJimmy
$77.42 - Out of stock
This Vizio 0500-0612-0030 Power Supply / LED Board for M550NV (0500-0612-0030) works for these ... The odds we'll get it soon: Bad (What does this mean?).
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no power service repair ... I can not get it to power on so I ...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/http://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Corrupted firmware. An update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Firmware upgrade procedure to many TVs and other devices are given with illustrations.
? 6:13
DiY How to Fix led / lcd Vizio TV service repair - no powerservice repair review guide no red blinking led ... Theorange/amber light turns on when plugged in. But the TV won'tturn on after that (the light does not turn white).
? 4:01
https://www.youtube.com/watch?v=MDzCzZdgbdg
Jan 5, 2012 - Uploaded by Leo P
This is model XVT3D424SV, I was watching a DVD, I switched the input to TV, tried to connect to netflix, it was ...
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/http://electronicshelponline.blogspot.com/http://electrohelponline.blogspot.com/
You might have to check different set-up codes; to get one that controls the volume function. This is a trial and error procedure, to universal remote controls of all brands. Might take some time too; to get the proper code you want to.
