20 Most Recent
Onkyo TXSR508 Receiver Questions & Answers
No audio from center channel
You could check your voltages before and after you loose audio and see where the voltage changes. Working backwards from output to input. I use a signal tracer or a small wattage speaker such as a
ear bud. If you don't have access to a oscilloscope.
when using an ear bud I would start at the driver(low wattage)
the pa would blow it.
I have my television, cable
The only way you can do this is by connecting the Cable Set Top box HDMI directly to the TV HDMI input and switching the TXSR508 to Apple TV. And if you want to hear the Cable sound through the TXSR, connect analogue audio out of the TV to one of the analogue inputs of the TXSR ( Aux or Video In ). You may not get the Cable TV's Dolby 5.1 sound but you will get stereo sound which on using the TXSR's dsp setting ( ProLogic II ) can be made into 5.1.
Hi, I have brought an
The reason you are not getting a good picture is because of the HDMI interlink cable. Make sure that the HDMI cables you have bought are at least version 1.3a. May be one of the cables is v1.3a that is why you are getting OK picture when you connect the projector directly ( it might be an expensive cable ) . If you do not get v1.3 you may also buy v1.4 which is 3D ready.
The poor band width of the cable must be giving you a bad picture.
Now if both your cables are OK and you are still getting a bad picture you have faulty HDMI pass through circuit on your TX-SR508.
My son is using the HDMI output from his SR508
Onkyo has a mod. for some units hdmi problems. I believe yours is one of them. It needs 4 capicators to be installed. I don't know if All Brite is an authorized servicer or not. If they are they shoud be able to access the info for the repair.
I have a PC 7.1
hi,
if u want to hear all the 7.1 channels u have to play videos which have 7.1 channel audio. if u play normal video with 5.1 channel, the u have to select listening in the AVR,
ok
0-83 error on onkyo tx nr 555
The 0-83 error indicates a problem with the firmware update.
Try resetting the receiver's BIOS by following these steps2:
Unplug all cables
Un-Power the receiver
Power the receiver
Before the receiver gets into the "Enter for updating" message, press Tone + CBL/SAT + ON/STANDBY. This will show you either the volume numbers or get you into settings of the receiver's speaker configuration.
Press CBL/SAT + ON/STANDBY. This will clear the BIOS and show a "Clear" message on the display. Wait until you hear a couple of clicking sounds for the receiver to turn on and off the power.
TX-NR555 Owner's Manual - Onkyo Product Support (onkyousa.com)
Onkyo nr 555 stuck on recovery:NET
Hello
Did you update the AVR over the internet?
If so the device wont work anymore.
You need to service the device in a nearest Onkyo service department.
Regards
Onkyo powered subwoofer SKW-791
Oknkyo SKW-791 has build in amplifier. So it can be connected through Line Out Connector of sansui amplifier. If speakers out is connected with subwoofer, the circuit board in subwoofer will be blown.
