20 Most Recent Cyberhome CH-LDV1010RS Portable DVD Player Questions & Answers
INSERT DISC PLAYER STARTS TO READ,AFTER A READING
The disc drive is not reading and so after it tries on for some time the drive does not detect and so fails to read. You can try and clean the optical lens unit manually using an ear bud with delicate wipes on the lens eye. If this wont change the error then the optical unit is faulty and will need a change.
4/12/2011 4:31:46 AM • Cyberhome... • Answered on Apr 12, 2011
DC Adapter (Internal part is missing)
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for CYBERHOME CH-LDV 1010
6/1/2009 11:40:04 PM • Cyberhome... • Answered on Jun 01, 2009
No charger. can i use batteries?
you still need to charge it, with a charger
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger CYBERHOME CH-LDV 1010 CHLDV1010
5/31/2009 7:37:06 PM • Cyberhome... • Answered on May 31, 2009
Broken power jack
If it's shoved all the way in and was connected to the pc board inside the unit you will probably need to buy another one. The only way to fix this is to open the unit up and repair the jack.
5/31/2009 3:17:03 AM • Cyberhome... • Answered on May 31, 2009
My cyberhome will not change hq,to sp,ep and soforth please helo thanks
Romy... there are "membrane switches" located behind the front panel. Sometimes they go bad or get dirty and won't work. tactmembrane-switch-o5myk4hhi5b5q5if45zblvzs-4-0.png MOST times these are a SINGLE panel with many switches. Often they are a pain to GET and install... Only the right one will work! switch-o5myk4hhi5b5q5if45zblvzs-4-2.png Anthony
5/20/2018 8:14:15 PM • Cyberhome... • Answered on May 20, 2018
0answers
Ge remote control, I have lost manual for the codes and I need code for a cyberhome CH DVD 300 remote model number is 27985 CL3 31601 could you please send me those codes to my DVD player thank you
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
1/1/2017 4:30:51 AM • Cyberhome... • Answered on Jan 01, 2017
Is the cyberhome1600 digital or analog also weir is the website for this cyberhome 1600 and can I get a replacement remote controle
All DVD is digital. Amazon sells remotes for this unit.
10/17/2016 4:00:12 PM • Cyberhome... • Answered on Oct 17, 2016
I lost my remote to my CyberHome CH-DVD 300 plus it's in Progressive Mode, what can I do ?
Without a remote control, you can't select anything with this set. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
10/3/2016 4:22:29 AM • Cyberhome... • Answered on Oct 03, 2016
Put dvd in reads it says no disk
Try a dvd lens cleaner
2/7/2016 11:44:14 PM • Cyberhome... • Answered on Feb 07, 2016
I need the code for a CyberHome DVD Player
UNIVERSAL REMOTE CODE . Find all the code you need for your universal remote.
Aiwa = 0641, 1912 Anam = 1913 Apex Digital = 0672, 0717, 0755, 0794, 0796, 0797, 0830, 1100, 1915, 1937 Audiovox = 0790 B & K = 0655 Blaupunkt = 0717 Blue Parade = 0571 Broksonic = 0695 Cambridge Soundworks = 1916 Cinevision = 0876 Classic = 1917 CyberHome = 0816, 1019, 1023, 1024 DVD2000 = 0521 Daewoo = 0784, 1918 Denon = 0490, 0634 Emerson = 0591 Enterprise = 0591 Fisher = 0670, 1919 GE = 0522, 0815, 0717 GPX = 0699, 0769 Go Video = 0715, 0783 Gradiente = 0651 Greenhill = 0717 Harman/Kardon = 0582, 0702 Hitachi = 0573, 0664 Hiteker = 0672 IRT = 0783 Initial = 1931 Integra = 0627, 1924 JBL = 0702, 1926 JVC = 0558, 0623, 0867, 1901 KLH = 0717, 0790 Kenwood = 0490, 0534, 0682 Konka = 0711, 0719 Koss = 0651 Lasonic = 0798 Magnavox = 0503, 0675, 1914 Malata = 0782 Marantz = 0539 Microsoft = 0522 Mintek = 0717 Mitsubishi = 0521 Nesa = 0717 Norcent = 0872, 1923 Onkyo = 0503, 0627, 1924 Oritron = 0651 Panasonic = 0490, 0632, 1362, 1490, 1907, 1908, 1909, 1910 Philips = 0503, 0539, 0646, 0854, 1914 Pioneer = 0525, 0571, 0632 Polk Audio = 0539 Proscan = 0522 Qwestar = 0651 RCA = 0522, 0571, 0717, 0790, 0822, 1022, 1913 Rotel = 0623 Rowa = 0823 Sampo = 0698 Samsung = 0573, 0820, 1932 Sansui = 0695 Sanyo = 0670, 0695, 0873 Sharp = 0630 Sherwood = 0633 Shinsonic = 0533, 1931 Sony = 0533, 0864, 1533, 1903, 1904 Sylvania = 0675, 0821 Technics = 0490 Theta Digital = 0571 Toshiba = 0503, 0695, 1045 Tredex = 0799 Urban Concepts = 0503 Venturer = 0790 XBox = 0522 Yamaha = 0490, 0539, 0545 Zenith = 0503, 0591
5/7/2015 4:43:04 AM • Cyberhome... • Answered on May 07, 2015
Cyberhome CH-LDV1010RS Portable DVD Player Logo
5 questions posted
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Cyberhome Televison & Video
Most Popular Question
insert disc player starts read after
  • Televison & Video
