20 Most Recent
Daewoo SD-8100 DVD Player/VCR Questions & Answers
Place a tape inside vcr and it just says 'error'
I had this exact same issue with a TEAC VCR a couple of years ago. The problem was the mode switch/loading motor. A new loading belt and new mode switch fixed the problem.
In this case, I would be pretty sure the mode switch is not allowing the mechanism to fully load correctly, hence the 'error' on the display. A new mode switch is inexpensive as a part by itself, but the labour involved by a workshop to fit and align it to the mechanism to it could be costly, but you can always obtain a quote beforehand; that way you can decide if it is worth getting the VCR fixed (because it is a combo unit with DVD player, I can totally understand this). As long as the DVD part works fine, you can go ahead with a workshop repair on the VCR, since this is a straightforward issue which is fixable.
It is up to you, you can always say no if the repair quote/labour cost is likely to exceed the value of the unit.
The good news is this 'error' with the VCR is easy to correct - in a workshop by a qualified technician. I don't recommend that you attempt to service this unit yourself unless you have considerable experience with electro-mechanical devices such as VCRs. These are complex machines, and the alignment of such requires an expert with service manuals, adequate stock of spare parts, and all the necessary equipment to do this properly. Hence why I suggest the quote.
You could clean the mode switch with an aerosol electronic cleaner (available from places like Radio Shack), but this will not last very long and is not reliable. Whenever this issue occurs, and the switch is found to be the culprit, it must be replaced/mech. re-aligned/re-timed; since these are not cleanable items as they develop high resistance on their internal contacts.
Fingers crossed that it is a cheap enough repair overall.
Diagrama tv dw19tt daewoo
I think it uses the 150 common chassis motherboard.
https://www.manualslib.com/manual/2480552/Daewoo-Dlt-19w4.html
Daewoo cm905s no audio?
There could be a few potential problems if your Daewoo CM905s isn't making any sound. Make sure all the cables and connections are tight first. If it doesn't work, ensure sure the audio source is not muted and that your speakers are active. Replace the audio source or speakers if the issue is still not fixed.
Help my daewoo start button doesn't work all the rest do what is wrong please .
It is difficult to determine the exact cause of the problem without first inspecting the vehicle. A few possible causes could be a faulty start button, a faulty dashboard control module, a bad ignition switch, or a problem with the wiring around the start button. An auto mechanic should be consulted to diagnose the exact cause of the problem.
My daewoo tv suddenly turn black and power off
the rear of all TV has a sticker label with model.
like xya50zzz123445
50 " TV
yes send it to a shop.
seems the PSU is bad, or overloaded an that takes tests and meters to find. and service manual .both and skills
take it to a shop is always best. or go broke guessing
NECESITO LOS CODIGOS PARA TV DAEWOO DE UN CONTROL UNIVERSAL RCA414BHZ
no hay in el folio? Es possible que no hay para este especifica Tele... pero pueden investigar en otro conrol universal de RCA....possiblemente 0130 0004 0009 0100 0005 0138 0043 0140 0039 0252 0279 0444 0080 0042 0058. Utiliza cada una, hasta ver si una funciona... Bueno suerte
Necesito el codigo de un control universal
English: the universal remote codes for Daewoo TV are: 002 102 110 214 303 311 314 403 407 415 502 503 611 614 805 809 909. Try those - I hope they help a bit.
Spanish: los c?digos alejados universales para Daewoo TV son: 002 102 110 214 303 311 314 403 407 415 502 503 611 614 805 809 909. Intente ?sos - esperanza de I que ayudan a un pedacito.
I had to translate (roughly) from the asker's question. Here is where I got the list from:
http://dogbytecomputer.com/universal-remote-control-code-list.html
Would I be able to
I don't know if this will work, but try opening your dvd player with no dvd inside and with your controls press 0000 this hopefully will bring up a screen where your region settings are. Set it to 0 and press okay. This may make your dvd region free and should be able to play any dvds form any region
if not try here
http://www.dvdexploder.com/multihacks
