20 Most Recent
Daewoo P480 DVD Player Questions & Answers
Disc will not play
That player is at least 5 years old. The DVD market has changed a lot over the last 5 years. Blue ray and HD and now UHD and 4K so it is time to get a new player. Most places wont take a DVD back after you open it.
Manually open dvd tray
Look next to the DVD tray to find a small hole. Once you have found that hole use a small paper clip and straighten one part of the clip. Carefully insert that extended paperclip into the hole, if you meet resistance apply gradual pressure until the tray opens...if the tray does not open...Remove the paperclip end (straighten the paperclip again and reinsert the straight end of the paperclip straight into the hole. Once you meet resistance press gently again, if you feel the paperclip continue into the hole without bending, continue pushing until the try opens. This is the correct way to open a CD/DVD/Blu-ray tray with or without the power on. If you need further assistance, please ask... I’m happy to help further over the phone at
https://www.6ya.com/expert/steven_142d2a6ad692ab09
DVD is stuck
I figured it out....Butter Knife did the trick. Thanks anyway!
Daewoo P480
Make sure you have the complete model number including all letters and numbers. i looked on the daewoo site and could not see your number, Maybe you have another number? here is the site, if you do not see it there, contact them via email through the link im leaving you. http://www.e-daewoo.com/owners_manual.asp#CMB Good Luck
PS please do not forget to rate this thread.
Diagrama tv dw19tt daewoo
I think it uses the 150 common chassis motherboard.
https://www.manualslib.com/manual/2480552/Daewoo-Dlt-19w4.html
Daewoo cm905s no audio?
There could be a few potential problems if your Daewoo CM905s isn't making any sound. Make sure all the cables and connections are tight first. If it doesn't work, ensure sure the audio source is not muted and that your speakers are active. Replace the audio source or speakers if the issue is still not fixed.
Help my daewoo start button doesn't work all the rest do what is wrong please .
It is difficult to determine the exact cause of the problem without first inspecting the vehicle. A few possible causes could be a faulty start button, a faulty dashboard control module, a bad ignition switch, or a problem with the wiring around the start button. An auto mechanic should be consulted to diagnose the exact cause of the problem.
My daewoo tv suddenly turn black and power off
the rear of all TV has a sticker label with model.
like xya50zzz123445
50 " TV
yes send it to a shop.
seems the PSU is bad, or overloaded an that takes tests and meters to find. and service manual .both and skills
take it to a shop is always best. or go broke guessing
NECESITO LOS CODIGOS PARA TV DAEWOO DE UN CONTROL UNIVERSAL RCA414BHZ
no hay in el folio? Es possible que no hay para este especifica Tele... pero pueden investigar en otro conrol universal de RCA....possiblemente 0130 0004 0009 0100 0005 0138 0043 0140 0039 0252 0279 0444 0080 0042 0058. Utiliza cada una, hasta ver si una funciona... Bueno suerte
Necesito el codigo de un control universal
English: the universal remote codes for Daewoo TV are: 002 102 110 214 303 311 314 403 407 415 502 503 611 614 805 809 909. Try those - I hope they help a bit.
Spanish: los c?digos alejados universales para Daewoo TV son: 002 102 110 214 303 311 314 403 407 415 502 503 611 614 805 809 909. Intente ?sos - esperanza de I que ayudan a un pedacito.
I had to translate (roughly) from the asker's question. Here is where I got the list from:
http://dogbytecomputer.com/universal-remote-control-code-list.html
