20 Most Recent
Daewoo DVN-14F6N 13" TV Questions & Answers
The menu does not have a choice to change from antena to cable how do I get it on cable
Typically, your cable box will have two inputs & one output that goes either thru your VCR for recording puposes or just direct to the TV. Your switching will happen thru your cable box, like an A/B switch, designed so that when cable is down, you can switch over to locally broadcasted TV stations. With DTV now in play in most areas, you will want to connect the antenna's connector to your DTV box, then connect it to your cable box for switching back and forth. The new flat panel TVs already have a digital receiver built-in, so in that case you would eliminate the DTV box.
I connected audio and video
You must select "AV in" mode on the Remote to get the signals on this connection.. If your TV has more than one input (one at the back too) than you have a selection of "AV1" and" AV2 " to switch on these two..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue for Helping out the Community :)
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Cable to Antenna Issues
You would need to purchase a universal remote, and once you program the universal you would be able to change from cable to antenna or vice versa.
Although there is a slim chance that in the setup screens on your TV (if you can access them by pushing a button on the tv) would have a selection where you could change the 'input' that is selected. If that is not an option, then it is definitely time for a universal remote.
Diagrama tv dw19tt daewoo
I think it uses the 150 common chassis motherboard.
https://www.manualslib.com/manual/2480552/Daewoo-Dlt-19w4.html
Daewoo cm905s no audio?
There could be a few potential problems if your Daewoo CM905s isn't making any sound. Make sure all the cables and connections are tight first. If it doesn't work, ensure sure the audio source is not muted and that your speakers are active. Replace the audio source or speakers if the issue is still not fixed.
