20 Most Recent
Sharp AL-1641CS Copier Questions & Answers
My copier will scan from the document feeder but
The scanner moves all the way over to the right when you use the doc feeder, so I doubt it is the motor. Also it would give you a code. What does it do when you use the glass? Make sure the cassette is selected and not the side tray.
Copier flashing between L and 1.
Hello sir;the trouble code display, means the scan unit have problem, check the scan unit does it move forward and backward is ok? or mirror motor not working final check out the scan cable is come off ?
FLASHING DISPLAY -
The problem on your machine is on the fusing unit, the temperature in
the fusing unit is low to start the machine. To cancel the trouble
status follow these steps:
Press CONTINOUSLY the following:
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not do again step 1 until the display turns off.
STEP3.press 14 then press print button
The
machine will now cancel the trouble status and ready to used. If not canceled and again H4 exist it means that there is a part inside the
fusing unit that is busted like the thermostat. With this you should
now contact your authorized serviceman to check your machine .
We have a Sharp 1641CS copier and the drum light
If you will replaced the drum you should reset the drum
counter .
To reset follow these steps:
Step1: Press continuously Clear key then press Exposure
key then Clear key then Exposure key
Step2: You are inside the simulation if the display turns
off but if not do again step1
Step 3: Press 24 then press print button then press 7 then
print button
If not canceled try step4
Step4: Do step1 to step2 then Press 24 then press print
button then press 6 then print button
