20 Most Recent
Sharp SF 2540 Copier Questions & Answers
Error code h5
That error aprears from having the same paper jam over and over. It is possible that you did not get all of the paper out of the machine. Otherwise most likely you have an issue with a sensor in the paper path you could try blowing all the sensors with canned air. Turn off both power butmtons or use sim 14-1 to clear the trouble and have it try starting up again. I’m happy to help further over the phone at
https://www.6ya.com/expert/ethan_e84416e0b13809d2
After powering on, it will show F2 on the Sharp SF
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,replacing toner cartridge rarely helpsseeing as it is a deeper issue
What is error F2 in
F2 in sharp means, aproblem related to toner supply make sure the proper catridge is inserted, check with another toner catridge to make it clear that crum on the toner catridge is still good, then if the problem again continues you try to change the developer, next is ATC sensor and the next is developer unit if you have any queries feel free to contact me and rate me
I have sharp AR-163 it
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
