20 Most Recent
Sharp AR-M355N Copier Questions & Answers
I'm trying to use my
When scanning to e-mail you would need to enter the details of a smtp server e.g. Gmail, as well as your DNS settings into the photocopier via the web browser. To access the browser, enter the I.P. address of the copier into the web address & this will give you the front page of the copier. To access the network settings you'll need the user name : admin & the password Sharp. Depending on the firmware version the machine must have SSL installed, if it hasn't then unfortunately you will not be able to scan to e-mail. The alternative is to scan to SMB (folder), again this is set up via the web browser.
Hope this helps.
Dave.
I Cannot Receive a Fax - the pages are blank
A second line isn't needed, this wouldn't cause blank pages to be printed. This could cause fax's not to be received if the line is in use. There could be 2 causes of blank fax's. Either the obvious which is the person sending the fax is faxing the document the wrong way up. Or the fax board on your copier has a malfunction. Because of the copier's age, this seems likely, although i hope not. hope this helps.
Code F2-02
Have you tried the sim 25-1 to see what the toner value is? Sharp pretty much just says check the connectors and the toner sensor then replace the toner. If you are using refilled toners that could be the issue. These are the troubleshootings steps for F2-02 in SM.
Techsupport Printer
