20 Most Recent
Sharp AR-M455N Copier Questions & Answers
How to fix a sharp ar-m455n error code u2-81
Dear sir; This error code means "scannor memory" problem, don't worry, we can reset it, the procedure as follow;
1, make sure you are in copy mode , then press "p", "*", "clear", "*".
2, enter 16 press start.
3, press "CA" to end simulation.
that's easy, if you need more help, just let me know, good luck.
HAVE A HAPPY HOLIDAY !!!
Code H5-01 on Sharp AR-M450N.
H5-01 is repeated jamming in the fuser unit, please check you have removed all paper from the heat section. press P/# * C * then 14 and copy start and follow the instructions on screen to reset.
SHARP M455N PRINTING LIGHT
The ink toner is is now infected by foriegn matters by effecting the printer laser head.Tries air compressor machine blow out the ink toner print head ink injector and laser printer print head.Wait about and hour reinstall the the ink toner to the printer,the toner should work find again.Not the ink toner is not saveable,must have be replace for normal operation again.
Our Sharp ARM455N Copier shows "Maintenance
this is message that the copier did certain amount of copies and it needs to be cleaned and ispected. The purpose of preventive maintenace is to stop or reduce problems before they occure. In most cases they occure when you need the copier urgently.
This can be reseted in simulation mode, but I recommend to get service technician to service the copier.
If you want to reset the alarm leave the email and I'll send you the service manual.
Tray
sir my machine sharp AR-m420u take code H3-01 whats meen this code......?
How do I remove the hard drive on a AR-M455N
If you have a finisher installed on your machine or any other accessory it needs to be removed. Then on that right side the panel comes off with 2 shouldered screws. Next you have to remove the HDD cover which is located right at the top almost centered on that right side. Its 2 screws and you remove the HDD connectors and then unscrew the the HDD from the frame.
Error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
