20 Most Recent
Sharp AR-M450N Copier Questions & Answers
Where is the finisher lock located?
The finisher lock is the screws, the top one it looks like is just a bracket but pulls out towards you, and unlocks it. then do the rests in the back and the 2 in the bottom of the unit ( pull the paper tray to see them). You should be able to remove the all unit by disconecting the plug in the back of the paper tray cabinet.
ERROR F 03 EN COPIADORA SHARP MX363N
If this is the code F1-03 then you have motor trouble within the finisher that I am assuming is fitted to your machine. Try entering this code to reset it.
Press # * C * and when the screen asks for a simulation number type in the number 14. Now press the start button (the key you press to make a copy). On the screen press execute and then confirm yes. Once you have done this press CA.
This may help but if a motor has failed its likely that the code will reappear.
Good Luck
Follow me on Twitter @CDOS_Service
Toner sensor reset
Try to install another new toner cartridge, you may have a defective toner????
