20 Most Recent
Monte Carlo Fans Kimberly 5KBR54 Ceiling Fan Questions & Answers
Where could I buy the
If you go to Monte carlo's website,
www.montecarlofans.com, and in the upper right hand side of the screen there is a search bar. If you search for your model number you will realize that they discontinued that model of fan. They won't have a motor for a discontinued fan unless they use the same motor for another model fan (not likely), but I took the liberty to call and find out for sure. The answer is no, they are discontinued. Sorry, but looks like you need a new fan.
Our fan is going in the reverse direction...how do
mcdevito75 here, Generally, The Fan switch itself is a pull chain type switch on the fan motor itself, this is a fan speed switch, NOW! also generally the reverse fan swtich is another shorter pull chain switch just about an inch away from the Fan Speed switch or the longer pull chain switch on the fan motor. This reverse switch can also be a toggle type or slide type switch but will be close to the fan speed switch on the fan motor itself.
Very suddenly neither fan or attached light work!
It sounds like one of the wires has become disconnected. This is not good, as it could create a fire hazard. Pull the power to the fan and open it up to inspect the wiring. Tighten connections and then try again.
Good luck,
I have a model 5BS520C.
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Remote not working
You really don't need reverse. You can call Monte Carlo if you really need this at 1-800-969-3347
