20 Most Recent
Briggs & Stratton 5 Hp Outboard Service Manual On Cdrom (Briggs Stratton) Questions & Answers
Gas spits out muffler
if gas is making it to you muffler that mean it getting way to much gas, but you would a ssume it would flood out. it could just be running out of your carborator and down the inside and seeming like its from the exhaust. end result check to make sure your carb floats are at the correct height or the motor get to much or to little of fuel
6/24/2014 5:25:32 PM •
Briggs &...
Answered
on Jun 24, 2014
Mazda 2 service manual
you can find almost any file if you look in free pdf files all you have to do is google it. good luck worse case go to your local library.
8/21/2013 6:57:54 PM •
Briggs &...
Answered
on Aug 21, 2013
Where can i obtain a
Hi, you can get one through any Briggs and Stratton dealer. Regards Phil.
12/13/2011 4:06:35 PM •
Briggs &...
Answered
on Dec 13, 2011
Do they all 5 hp
Your idle speed is to high. These have (most of them) a wire wound round a drum for the clutch (called a bendix clutch) and it is very positive. so your idle must be real slow not to damage. it. If the engine will not run slow it's most likely problem is mixture adjustment after that would be the bottom seal.
12/13/2011 4:03:51 PM •
Briggs &...
Answered
on Dec 13, 2011
I would like a manual to order parts
I can not find you a manual for free download. All links I found have been removed, due to Briggs is discontinuing the Outboard production and sells of the motor. The only solution I have is for you to contact Briggs and Stratton support for help
1-800-444-7774. or E-bay. Here is a link to a site that sells the manual,
Small engine manual... . Hope this helps FixYa up.
9/3/2011 9:00:57 PM •
Briggs &...
Answered
on Sep 03, 2011
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM •
Boating
Answered
on Dec 05, 2023
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin
Cruisers are 20-40 feet. There are of course larger Yachts that can get to over
100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM •
Boating
Answered
on Nov 15, 2023
What is the most expensive yacht in the world?
Off-course There are so many companies who are offering expensive yacht charter for rent in and around Europe. I suggest you to enter Kavas is the only yacht chartering company in Greece with over 25 years of experience in our industry. Kavas is offering all range from reasonable to luxury yacht services in Athens, Kos Island and Lefkas Island. For more details visit
Bareboat or Crewed Yacht Charters in Greece
10/13/2023 4:52:02 PM •
Boating
Answered
on Oct 13, 2023
