20 Most Recent Brother Dcp395cn InkJet Printer Questions & Answers
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Brother Dcp395cn... | Answered on Aug 07, 2011
You can try calling Brother at 1-877-276-8437 and they should be able to tell you where to take the unit to have it repaired under the warranty. This is a very common problem that Brother is well aware of; the printhead will need to be replaced.
Brother Dcp395cn... | Answered on Jun 09, 2011
Some printers automatically print automatic duplex printing, other printers allow you to manually reinsert pages to print the second side .and some printers do not support duplex printing at all.
To find out whether your printer supports duplex printing, you can check the printer manual, contact the printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box
Note that If you have more than one printer installed, it's possible that one printer supports duplex printing and another printer does not.
Brother Dcp395cn... | Answered on Mar 28, 2011
Make sure the cartridges are proper and there is no dust on nozzle just clean with tissue paper and also use brother photo quality paper that is special type paper use that.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Brother Dcp395cn... | Answered on Dec 29, 2010
Recommend contacting Brother directly
Brother DCP... | Answered on May 20, 2018
maintenance unit is not working normally. See if any thing is stuck or replace it.
Brother DCP... | Answered on Sep 02, 2017
Error code EF - Irregular power supply is detected
Print Unable EF
Turn the power off and then back on again.
Brother DCP... | Answered on May 25, 2017
Turn off the printer and unplug it from the power. Then press and hold the power button for 1 minute. Now release the button, plug in the printer and turn it on and see if the error clears.
If it doesn't fix the issue, you probably have to replace the cartridges. They will cost about $65. Good luck!
Brother DCP... | Answered on Mar 13, 2017
See if you can find the printer driver online (manufacturer's web-page maybe) and install the driver before you connect the printer.
Brother DCP... | Answered on Aug 19, 2016
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_440CN_665CW_845CW_EN_287.PDF
Under the troubleshooting section(pg.154) it lists this error as having one of two possible causes:
just do CTRL plus f to find
Unable to Clean XX
in the pdf document
As you failed to mention the model number it may not be your model number but the basic principal will be the same on the cause.
Brother DCP... | Answered on Jun 12, 2016
This is a common occurrence for these machines. They can get confused when cartridges are changed before they read as empty.
To correct this.
1) Unplug the printer from both the Power and Computer and remove all cartridges closing the cartridge access panel.
2) Plug the printer into the Power only and turn on. The machine will complain about no cartridges, this is fine.
3) Open Ink access panel and insert the first cartridge (Black is most common and close the panel.
4) The machine will complain about the missing cartridges. Open the panel and insert the second cartridge in the sequence and close the panel again.
5) Repeat the process for the third and fourth cartridge.
6) Once all cartridges have been installed the printer will ask if you have replaced the cartridges. Say no to the Black, Cyan and Yellow but yes to the Magenta and it will display the correct readings.
If this process fails to read the cartridge still then there is something wrong with the sensor inside the machine which probably means new machine.
Brother DCP... | Answered on Jun 04, 2016
Brother Dcp395cn InkJet Printer Logo
Popular Tags
11 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
DCP Brother
  • DCP Brother
Most Popular Question
black ink blocked
  • Office Equipment & Supplies
