20 Most Recent Cakewalk VStudio 20 Audio Interface USB Questions & Answers
Check that in the control panel of Windows, "Sounds and devices" your interface is the default device in each of the panels under the tabs such as "Voice" and the others.
Cakewalk VStudio... | Answered on May 03, 2011
OK so let me answer the request
Just go to
https://support.casio.com/en/manual/manualfile.php?cid=008001026
Good luck, I hope this helps.
Dan
Music | Answered 2 days ago
When distribution came back to B.C. Rich in 1974, a system of serial number coding began using a 5-digit code (XXYYY) with the first 2 digits indicating the year and the last 3 indicating the production number. That would make the first guitar of 1974 to have been numbered 74000, followed by 74001, 74002, 74003, etc. Throughout the '70s, production numbers were low enough that the serial numbers pretty much reflect the year of manufacture.
Music | Answered on Jul 16, 2019
Many if not all of the portable pianos use a pedal with a 1/4 inch jack. Different manufacturers will use electronic switching circuitry that requires polarity of the switch to be "open-normal" or "close-normal".
A pedal can be purchased on amazon that allows you to choose the polarity.
Here is the link:
https://www.amazon.com/Universal-Electronic-Keyboard-Flanger-FTB-004/dp/B073PZVSQ2/ref=asc_df_B073PZVSQ2/?tag=hyprod-20&linkCode=df0&hvadid=198057020828&hvpos=1o3&hvnetw=g&hvrand=17008650641004582428&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9007519&hvtargid=pla-447512875637&psc=1
Music | Answered on Jul 12, 2019
try using an electrical contact cleaner on them...?
it's hard to provide a clear answer though...
without knowing what kind of buttons they are, what they're on, and what they're supposed actually do.
just sayin'
Those piano schools are considered as ideal, which provides lessons tailored to the individual needs of each student. They should teach all age groups from kids to elderly and all sorts of people from beginners to experienced musicians. And their teaching must cover classical as well as other genres like jazz. Info: https://www.europeanpianoacademy.com.au/
Music | Answered on Jul 09, 2019
The Chain, Fleetwood Mac
Music | Answered on Jul 05, 2019
Try Bandcamp as they only take a small percentage! I have a friend who can't recommend Bandcamp enough!
Music | Answered on Jun 29, 2019
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Music | Answered on Jun 25, 2019
First of all, select the dress and gather all supplies like a pair of earplugs, glitter markers for taking autographs and some cash. You can read more about this here https://m.wikihow.com/Prepare-for-a-Concert. In the same token, don't forget to recheck the venue, dates and any other requirements from here https://concerts50.com/ according to your state or location of the concert.
Music | Answered on Jun 23, 2019
Cakewalk VStudio 20 Audio Interface USB Logo
1 questions posted
Top Cakewalk Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Cakewalk Music Expert? Answer questions, earn points and help others
View Most Popular
Cakewalk Music
  • Cakewalk Music
Most Popular Question
cakewalk v20 lost connection
  • Music
