20 Most Recent Epiphone Sheraton II Guitar Electric Hollowbody Questions & Answers
Sounds like the toggle switch needs to be replaced. If unfamiliar with the procedure, take it to a repair shop.
Epiphone... | Answered on Jan 02, 2015
the switch, has three positions. Typically forward or up will be your neck (or rythm) pick ups, only and will work with one volume knob(usually top right as your looking at guitar), and one tone knob ( top left as your looking at the guitar). when the switch is in the far right or all the way down position, that will be the saddle (or lead) pick-ups. And that works with only one volume knob(bottom right as your looking at the guitar) and the corresponding tone knob. when the switch is in the middle position, botjh volume knobs work and both tone knobs work. You've gotta kinda play around with them to find whatever sound yopur looking for. and tone knobs are very subtle in their changes. good luck
http://www.epiphone.com/images/StringGauges.pdf, i could only find these.
Epiphone... | Answered on May 18, 2011
Most likely it is wired like most Gibsons. The volume knobs are the two at the neck end, the tones are the two nearest the rear. The lower two are volume and tone for the bridge pickup, the upper two are for neck pickup. Switch down is bridge or lead pickup, switch up is for neck or rythym pickup, and centre position is both pickups one, where all knobs can be used together.
Epiphone... | Answered on Mar 05, 2011
Adjust this using the EQ on the amp and to a lesser extent the tone controls on the guitar.
Often people boost the bass way up causing this problem.
Epiphone... | Answered on Feb 12, 2011
Sounds like perhaps a Les Paul Special II, but more detail is needed to say for sure. There was a lot of variation in their Les Paul models. Posting a photo of both sides and the headstock is best.
-Has the guitar any binding, and what colour?
-Is the back of the guitar white or all black?
-Exactly what is on the front of the headstock, 'Epiphone', the 4-diamond logo, anything else?
Epiphone Music | Answered on Sep 11, 2019
The controls should be setup in pairs (as long as the electronics haven't been modified. The two closest to the pickups are the volumes and the other two are the tone controls. The top knob set should be your neck pickup and the bottom set is for the bridge.
Schematics and wiring diagram for the typical les paul (sheraton) controls:
http://www.guitarelectronics.com/product/WDUHH3T2202
Approx 1965. Cant determine value without model #
Epiphone Music | Answered on Aug 21, 2019
Possible manual from manufacturer web site found using https://www.google.com
May be a different model than yours.
http://images.epiphone.com.s3.amazonaws.com/Media/Manuals/EpiOwnrsManul.pdf
Epiphone Music | Answered on Aug 13, 2019
Request the wiring diagram directly from Epiphone.
Epiphone Music | Answered on Jul 10, 2019
The Epiphone serial number decoder, I use, supports 12 serial number formats from 25 factories. Vintage numbers from 1932 to 1970 are supported. Serial numbers from 70' and 80's era Epiphone guitars made in Japan are not supported. The reason for this is that there is no reliable documentation from this time period. This Module has been updated to work with the newer serial number formats. Looks like your Epiphone is Japanese. Try a guitar dealership or contact Epiphone for advice.
Epiphone Music | Answered on Jan 29, 2019
Epiphone - The Guitar Dater Project - Epiphone Serial Number Decoder
https://www.guitardaterproject.org/epiphone.aspx
The Epiphone serial number decoder currently supports 12 serial number formats from 25 factories. Vintage numbers from 1932 to 1970 are supported. Serial ...
Epiphone Serial Number Decoding - Gibson Brands Forums
forum.gibson.com > Gibson Brands > Epiphone > Epiphone Acoustics
Oct 30, 2017 - 5 posts - ‎4 authors
This serial number formats is solely used on Epiphone Elite or Elitist models. ... F-Serial Numbers onLes Paul Standard '59/'60 Models and ... Epiphone Les Paul Standard with TWO serial numbers?!?!
Dec. 11, 2011
Epiphone Les Paul Serial Number
Feb. 14, 2010
Look up your Epiphone Serial Number
Oct. 27, 2009
i.d. your Epiphone here -- serial # key, guitardater link + ...
Feb. 15, 2009
More results from forum.gibson.com
Gibson And Epiphone Guitars Serial Number Guide ' The Music Zoo
https://www.themusiczoo.com/blogs/.../gibson-and-epiphone-guitars-serial-number-gu...
May 4, 2011 - Les Paul Classic: This model features an ink stamped serial number with no "MADE IN USA" (just as we used on the original 1952-1960 Les Pauls). Most will be 5 to 6 digits in length, but the earliest examples feature 4 digit serial numbers.
Epiphone serial-number-information - identification ' Epiphone Guitars
www.epiphonetalk.com > Forums > The Guitar > Epiphone Guitars
Aug 11, 2017 - For Epiphone serial numbers that begin with a letter(s), this list ... F - Qingdao (China) = Les Paul Standard '59 / '60 / Tribute Models (See: ...
epiphone les paul standard serial number Google Search
Epiphone Music | Answered on Nov 26, 2018
That serial number was used more than once.
If it has 'Made in USA' on the headstock, it was made at the Bozeman Plant, MT, USA on July 21st, 2000.
Otherwise it was made in Korea in March, 2002.
Epiphone Music | Answered on Mar 31, 2018
That guitar was made in Korea in August, 2004
Epiphone Music | Answered on Jan 25, 2018
We don't do that here, check with them...
Epiphone Music | Answered on Dec 15, 2017
Epiphone Sheraton II Guitar Electric Hollowbody Logo
Popular Tags
7 questions posted
Top Epiphone Music Experts
Michial Gueffroy
Craig Butler
Craig Butler
Robert Graf
Are you an Epiphone Music Expert? Answer questions, earn points and help others
View Most Popular
Epiphone Music
  • Epiphone Music
Most Popular Question
am looking manual one
  • Music
