20 Most Recent Lenoxx Electronics Clock Radio With CD Player Questions & Answers
To Set the alarm time: Press and hold the ALARM button down, and then press the hour/minute buttons to obtain desired time (Note the PM indicator on the screen for PM times)
To Enable the alarm: Move the sliding switch to AUTO or ALARM (Auto is for radio wake and Alarm is for beeping noise) *remember to turn up the volume knob if using AUTO (radio) setting.
Lenoxx... | Answered on Oct 29, 2018
Hello
The sled motor of your player is not working. This is the motor that spins the disc inside as soon as it has been loaded. But to spin disc, the disc must be loaded properly into the loading mechanism. Just check the loading belt that attached with loading motor and loading gear set for any loose, which may cause improper disc loading. Replace it first. If it does not help you, check the voltage at the seled motor terminals. There must be a voltage [4.5VDC approx:]. If the voltage is there and still the sled motor does nor work, replace it. If voltage is not there, the fault is with the loading IC which is soldered to the main board of the device. OK>
Lenoxx... | Answered on Jan 05, 2012
if the problem came from the factory it may be unavailable for the model ...but also can be just a software issue ..and updating the firmware can fix it ..Remember that updating firmware is a 2 way street ..and can cause good ..and loose some functions in the same time ..so ..think twice before proceed with it ..If it works good..I would not make it unless is a have to do it matter ..
The firmware can be downloaded from the support site of the manufacturer..
Lenoxx... | Answered on Jan 20, 2011
I will advice you check either of any of this two sites amazon.com or ebay.com to get the replacement part you need for your device.
Take care.
Lenoxx... | Answered on Sep 04, 2010
A clue may help you get an answer.
Audio Players &... | Answered 1 hour ago
Hi Angela, you can try another outlet, if it does not work, check the power cord, which is not damaged, you could also check if it has a fuse
if none of this works, consult a specialized technical service
I hope you can solve it
Greetings Franco Dosil
Hola Angela, puedes probar en otro tomacoriente, si no funciona, revisa bien el cable de corriente, que no se encuentre da?ado, tambien podrias fijarte si tiene algun fusible
si nada de esto funciona, consulta un servicio tecnico especializado
Espero lo puedas resolver
Saludos Franco Dosil
Audio Players &... | Answered 2 hours ago
Hi Anonymous, connect passive speakers to a headphone amplifier, it will not work, the headphone amplifier is designed for that, headphones, they are very low power
You should use an amplifier, according to the power that your speakers can handle or use active speakers
I hope you can hear the sound of your TV on your speakers
Regards Franco Dosil
Hola Anonymous, conectar altavoces pasivos a un amplificador de auriculares, no va a funcionar, el amplificador de auriculares esta pensado para eso, auriculares, son de muy baja potencia
Deberas usar un amplificador, acorde a la potencia que puedan manejar tus altavoces o usar altavoces activos
Espero puedas escuchar en tus bafles el sonido de tu TV
Audio Players &... | Answered 13 hours ago
Lenoxx Electronics Clock Radio With CD Player Logo
7 questions posted
Top Lenoxx Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
matt
matt
Are you a Lenoxx Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lenoxx Electronics Audio Players & Recorders
Most Popular Question
unable set alarm
  • Audio Players & Recorders
