20 Most Recent
Frigidaire FRA256ST2 WallWindow Air Conditioner Questions & Answers
TIMER WONT TURN OFF
Good Afternoon Friend,
I understand the timer won't turn off, on you Frigidaire air conditioner, model# FRA256ST2. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try using the timer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Can i take my frigidaire ac out of the case without removing it from the window?
I understand that you want to know whether you can take your Frigidaire air conditioning, model# FRA256ST2, out of the case, without removing the case from the window. Yes you are. Below are step by step instructions for removing your air conditioning from the case.
1)Unplug your air conditioner.
2)Take the front grill off.
3)Remove the filter.
4)There are four panel screws, two on each side of where the front grill and filter were. Remove these screws.
5)Gently pull out your air conditioner.
For replacing your air conditioner, follow the steps in reverse. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer light status has changed successfully. Hope this is helpful.
-Best regards-
WP
Not blowing cold air
Hello, Here is a trouble shooting guide for you and some details of how
to fix it based on your symptoms. Here is a link to go to and make sure
you jump around the site, it will tell you the fix based on your problem
off the trouble shooting table. Link is below , copy and paste in
browser. If this helped you, please rate it and some kind words are
nice. Thanks Mike
http://home.howstuffworks.com/home-improvement/heating-and-cooling/how-to-repair-room-air-conditioners1.htm
AC does not start
I just bought this unit today an I'm having the same problem as you
Air conditioner has loud hollow sound
After mine set up, I turned it on and it made a steady clanking sound, turns out there is black foam that is supposed to be glued behind the cooling fan and it had come undone and was hitting the fan. Slide the unit out of its shell and reach your hand in there and see if anything has come loose. (the fan towards the rear of the unit) good luck.
The unit is only 4 months old. bought from lowes
Sears sells fridgidair parts. Go to sears .com under there appliance parts. You should
Find the part you need. You might want to check to make sure the sensing bulb for the
Thermostat is in front of the cooling coil just behind your air filter. If it not located properly
It can't properly sense the air temp. And may not shut down .
Our 4 month old Frigidaire
A dirty or clogged air intake filter will prevent the unit from turning ON, as a safety feature. If that isn't of doesn't solve the problem. Contact Frigidaire 1-800-944-9044. As you unit is still under 100% warranty at this point. They will repair it or replace it at their option. Don't do anything to the unit, that could possibly void the warranty.
Hope this helped you and thanks for choosing FixYa.
What is the serial number for fra256st2 frigidaire
Unfortunately, there is no way to know the individual serial number of each Frigidaire AC unit, as they are all different. Even the manufacturer, couldn't tell you the exact serial number from the model number, alone.
Hope this helped answer you question and thanks for choosing FixYa.
Less than a week ago
Hello
The control panel sensor is bad.I would take the unit back asap.There should be a 1 year warranty on the unit.
I cant take the front and back off of the air
The plastic front must come off. Usually the screws to take the front off are behind the front grille of the plastic front by the filter. The unit will probably slide out of the case when you get the plastic front off, but at times they will put a shipping screw through the back side of the case on a lower corner into the unit. This screw(s) will also have to come out.
