20 Most Recent Amana PTH093B35AJ 9100 BTU ThruWallWindow Air Conditioner Questions & Answers
Where is the Manual Heater Reset Switch on an Amana A/C and Heater Unit Model number PTH093B35AJ? The unit has several stickers that state it has a "Manual Heater Reset Switch".
Almost certainly it is a bad relay on the circuit board. Sometimes you can slap the side of the unit by the control box to temporarily unstick the relay, after which the heat will come on for a cycle or two. There are two relays on the circuit board marked "heater 1" and "heater 2". You can order a new circuit board for about $100 or replace the relays at $4 apiece (order online from Digi-Key, requires solder connections). Part number JTN1a-PA-F-DC5V.
12/14/2014 12:23:51 AM • Amana... • Answered on Dec 14, 2014
What if I replace 1/3 blower motor with 1/2 motor on Amana 80 SSE Furnace?
The important consideration is the rotational speed and adding extra horsepower really doesn't achieve anything because the motor isn't really under 'load' as it would be in say a winch. It is better to stick to OEM Specs https://www.google.com/search?q=amana+80+sse+blower+motor ..
2/6/2024 5:18:53 AM • Amana Heating &... • Answered on Feb 06, 2024
Amana DigiSmart PTH153B50AM 14000 BTU Heat Pump. What Amana model replaces PTH153B50AM please?
Question edited for a lot more clarity. The new improved energy efficient versions.
The Improved Amana R-410A PTAC Unit Uses Less Energy
Amana PTAC https://www.amana-ptac.com > products > ptac Looking to buy an energy-efficient PTAC unit for your building? Buy the new Amana R-410A PTAC unit heat pump, which reduces energy consumption by 35%. Probably this one. Talk to your installer. https://www.amana-ptac.com/products/ptac/hec154j ..
1/10/2024 5:01:34 AM • Amana Heating &... • Answered on Jan 10, 2024
Amana PTAC air conditioner. Switch to a wall thermostat?
Question edited for clarity and toss in some CAPS. You can get wired or wireless. https://www.amana-ptac.com/products/ptac Fitting https://www.google.com/search?q=amana+ptac+connect+to+wall+thermostat .
7/26/2023 3:29:14 PM • Amana Heating &... • Answered on Jul 26, 2023
I'm not getting any code after installing a control board for my Amana ptac?
Does the power light come on? If yes, then you can do a reset as below: There is a master switch on the bottom left of the control board. Slide that to 'off' position. Then press the hot and cold switch/key together and then slide the master switch back to 'on'. Please put your response/observation here if that does not work or there is power light as asked on top. Thanks
2/27/2023 3:44:12 PM • Amana Heating &... • Answered on Feb 27, 2023
2answers
Amana PTH153B50AM PTAC where the heat runs intermittently.
i'm not familiar with your specific unit but ..sounds like an electronic gas value has gone bad or has a bad connection when that happened to my friend it wasn't that expensive to have it fixed .. BYW it acted like this for a while then stopped working completely
1/23/2023 9:58:51 PM • Amana Heating &... • Answered on Jan 23, 2023
Amana window ac unit fan continues on and how to reset the unit
Hi, Please hit the "constant fan" button until the "on" button is removed from your Amana screen. Thank you.
10/24/2022 8:10:04 PM • Amana Heating &... • Answered on Oct 24, 2022
2answers
Amana ptac blower wheel not turning on , compressor and fan are working
blower capacitors or motor bad
9/28/2022 2:39:50 PM • Amana Heating &... • Answered on Sep 28, 2022
2answers
Amana pth153g35axxx in wall system and it is blowing air only we reset it and still not blowing any cold air, what causes this the system sound like it is running correctly but no cold air
you will need to call for service. if it needs freon you cannot recharge it freon is expensive and requires a license.
9/12/2022 5:42:17 AM • Amana Heating &... • Answered on Sep 12, 2022
Amana Wall unit blows cold air before heating
The cold that you describe may be just unconditioned air? If you are certain you can hear the comp operating for a couple of minutes, and then the heat starts, I would guess it is a reversing valve issue if it's a heat pump and it probably is. Or the control board acting up. I've had a lot of issues with the boards in the Amanda PTAC units. I can't remember how to configure it, but if you Google "Amanda ptac configuration", there is a lot of info online. May try a reset method first. Hope this helps!
8/3/2022 4:58:26 PM • Amana Heating &... • Answered on Aug 03, 2022
2answers
I have an Amana AP148D, can I run it without an
Self evaporating simply means there is a drain pan with a heater device installed that will evaporate and condensate that drains from the unit into the pan.
You do not need the external drain pan unless the unit makes more water than the drain pan and drain pan heater can handle.
5/29/2022 4:56:06 PM • Amana Heating &... • Answered on May 29, 2022
How to configure AMANA to only use the heating element and not the pump?
switch thermostat to emergency heat. Call for service the unit should be under warranty. Be aware that using heating strips will cause your electric to go extremely high.
12/18/2021 8:22:05 PM • Amana Heating &... • Answered on Dec 18, 2021
2answers
I hav a amana ap148d and it shut off and the
Empty the water pan. It not sealed so dont slosh it around. Mine did the same thing. Amana rep was an ***. Wouldn't give me an inkling of what to do. So i started to fiddle around. There was a lot of water in it Be careful. I brought mine to the tub and drained it for close to 2 min. Started right back up!
5/26/2021 3:08:04 PM • Amana Heating &... • Answered on May 26, 2021
Model PTH153B35AE A/C. Why is tray full and leaking inside?
If this is a window unit, the tray drain is located at the bottom outside. It may be clogged, but also the unit may not have been installed correctly to direct water flow toward the outside drain.
11/22/2020 4:05:01 PM • Amana Heating &... • Answered on Nov 22, 2020
Amana PTH093B35AJ 9100 BTU ThruWallWindow Air Conditioner Logo
2 questions posted
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
manual heater reset switch amana c
  • Heating & Cooling
