20 Most Recent
XFX GeForce FX 5500 Graphic Card Questions & Answers
Have a new 23 inch samsung monitor that requires res 1920x1080
The problem is the cable connection to the video card.
When using the DVI output of the FX 5500, the maximum screen resolution
that you can select is 1280 x 1024.
But, if you use the Analog (VGA) output, the card will
support resolutions up to 2048 x 1536, which should be ok.
I have nvidia gefore fx
I have this problem before and I tried to spend some time to sort it out but no success, the only way to resolve this is to upgrade (if still applicable) or buy a new computer.
Need driver for this PCI
You can download it from here
http://www.nvidia.com/page/drivers.html
But I'm afraid it's also gonna be around same size.
Where i am can download
Click on the bellow link to go to the nvidia drivers support page -
http://www.nvidia.com/Download/Select Product Type --Geforce
Product Series -Geforce 5 fx series
Product Geforce FX 5500
Operating System (windows xp,windows vista ,windows 7) --choose your OS.
Choose your language ..and click Search Button.Next click on Download button.
Regards
My graffic card is not working in win 7
hi staranhaa
- first u should install graphics card software properply and should copy and paste the crack file into the exact path...one method
- Then check in windows7 whether its a32-bit or 62-bit compatibility
- Then choose the compatibility and then installed it
- if its a desktop-pc means check the hardware too..
- In windows 7 is definetly supported by this grahics card...
After i installed its driver i can't boot into
Restart the PC and press F8 (a few times). It will give you a black screen with option to start the PC in safe mode and after starting the PC you should remove the drivers you have just installed. After restart you should be able to boot the PC and reinstall the drivers.
Click here to download the drivers for Nvidia GeForce FX 5500
Select GeForce 5 FX Series , GeForce FX 5500, choose the Operating System and download the required drivers.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Just installed a ge force fx5500 graphics card but
try to use various other lower settings, depending what type of monitor you have 1280x1024 may not be the right choice. for example a wide screen will need fewer vertical pixels
hope I was able to help
Inno3D Geforce 256MB 128bit Video card
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
Having problems installing a Geforce fx5500 on my dell deminsion
