20 Most Recent AMP ESTEBAN AMPLIFIER NEW Questions & Answers
The volume knob on my esteban g10 broke off
There is no other fix than to replace the volume pot. if you are not familar with working on electronics, it will require a trip to the repair shop. Unfortunately, the repair charges will most likely be more than the cost of just replaceing the amp.
12/15/2014 6:12:41 AM • AMP ESTEBAN... • Answered on Dec 15, 2014
How to get to the input jack on a bugera 62/62 amp head.
Repairing the input jack on your Bugera 6262 amp head is a task that requires careful attention and technical expertise. If you're comfortable with electronics and have experience working with amplifiers, you can follow these general steps to access and repair the input jack. However, please note that working on high-voltage electronics can be dangerous, and if you're not confident in your abilities, it's best to seek professional assistance.
  1. Safety Precautions:
    • Disconnect the Power: Ensure that the amplifier is completely unplugged from the power source before you begin any work. This is crucial to prevent electric shock.
  2. Gather Tools:
    • You'll need a set of screwdrivers (Phillips and flat-head) appropriate for the screws used in the amplifier's casing.
    • A soldering iron and soldering supplies (solder, desoldering braid, etc.) for working on the input jack connections.
  3. Opening the Amp:
    • Remove the screws holding the amplifier's chassis in the enclosure. These screws are usually located on the rear panel or sometimes underneath the amp. Keep track of the screws and their locations.
  4. Accessing the Input Jack:
    • Once the chassis is removed from the enclosure, you should have access to the internal components of the amplifier. Look for the input jack and its connections on the PCB (printed circuit board).
  5. Repairing the Input Jack:
    • Carefully examine the input jack's connections. If you see any loose or broken solder joints, you'll need to re-solder them. Use a soldering iron to heat the solder joint and apply a small amount of new solder if necessary.
  6. Testing and Reassembly:
    • After repairing the input jack connections, it's a good idea to test the amp's functionality before fully reassembling it. Plug in your instrument and ensure that the input jack is working as expected.
  7. Reassembling the Amp:
    • Once you've confirmed that the input jack is functioning properly, carefully reassemble the amplifier. Make sure to secure all screws and components properly.
8/6/2023 8:23:03 AM • AMP Music • Answered on Aug 06, 2023
PV IPR 3000 power amp turns on but does not produce sound output
It's most likely in over load protect, does it work with headphones?
7/9/2023 2:49:10 PM • AMP Music • Answered on Jul 09, 2023
The jack to plug the 50 wt street cube broke on the amp I need a replacement
I always fit Switchcraft jack sockets. Available from Farnell, CPC, RS, Mouser etc.
7/5/2023 5:25:45 PM • AMP Music • Answered on Jul 05, 2023
One channel on the monsoon set effects the 1500 amp and 10" d6 Diamond. What do I have to do to fix this issue?
If you are experiencing an issue where only one channel on your Monsoon set is affecting the 1500 amp and 10" D6 Diamond subwoofer, there are several troubleshooting steps to consider. Start by checking all the wiring connections to ensure they are secure and properly connected. Swap the speaker cables to determine if the problem lies with the cables or the channel itself. Test the affected channel with a different speaker to see if the issue persists, which could indicate a problem with the amplifier. Verify the subwoofer's functionality by connecting it to a different channel or audio source. Resetting or adjusting settings on the Monsoon set may also help.
6/18/2023 12:19:00 PM • AMP Music • Answered on Jun 18, 2023
This is a power amp for the floor speakers or monitors for P.A. system
Question resurrected from 2016 by addition and removal of spam. https://www.fixya.com/users/jackie-passmore You posted three questions all covering one question, but posts of Fixya are not linked, threaded or nested, so none of the questions have any context to the others. Questions can be Edited by you as you think of more things to add. ..
4/17/2023 7:54:42 PM • AMP Music • Answered on Apr 17, 2023
Hk elias
4/17/2023 4:05:59 PM • AMP Music • Answered on Apr 17, 2023
I have a pavey vypyr 100 watts amp how to find turner
4/17/2023 4:02:10 PM • AMP Music • Answered on Apr 17, 2023
Find the turner on a pavey vypyr 100 watts amp
4/17/2023 4:00:25 PM • AMP Music • Answered on Apr 17, 2023
I need a schematic for this amp Acoustic B450mkII
4/17/2023 3:08:03 PM • AMP Music • Answered on Apr 17, 2023
Need schematic for rca pa amp M1-12158
4/17/2023 3:06:56 PM • AMP Music • Answered on Apr 17, 2023
Wiring schematic for lectrolab guitar amp from the 19602
4/17/2023 3:05:27 PM • AMP Music • Answered on Apr 17, 2023
I have a VALVETRONIX VT15
4/17/2023 3:00:46 PM • AMP Music • Answered on Apr 17, 2023
Digitech vocal harmonizer
4/17/2023 2:38:50 PM • AMP Music • Answered on Apr 17, 2023
One of the XLR inputs on my Europort EPS500MP3 mixer amp has stopped working. What could be the problem please?
he issue you're describing with one of the XLR inputs on your Europort EPS500MP3 mixer amp not working could be caused by several factors. Here are a few steps you can try to troubleshoot the problem:
  1. Check the cable: Make sure that the cable is properly connected to the input and that there are no loose or damaged connections.
  2. Check the input: Make sure that the input is not damaged or malfunctioning.
  3. Check the channel settings: Make sure that the channel settings are set correctly and that the input is not muted or turned off.
  4. Check the gain: Make sure that the gain on the input is set correctly.
  5. Check the power: Make sure that the mixer is properly plugged in and that the power is on.
  6. Consult the manual: Consult the manual for specific troubleshoot and service information for your Europort EPS500MP3 mixer amp.
1/14/2023 1:15:41 AM • AMP Music • Answered on Jan 14, 2023
AMP ESTEBAN AMPLIFIER NEW Logo
1 questions posted
Top AMP Music Experts
MrFixitSTTL
ADMIN Eric
ADMIN Eric
Are you an AMP Music Expert? Answer questions, earn points and help others
View Most Popular
AMP Music
  • AMP Music
Most Popular Question
volume knob esteban g10 broke off
  • Music
