20 Most Recent Yamaha P95 Digital Piano Questions & Answers
Manual for Yamaha P 160 Need a Manual
For the P95 user manual visit https://uk.yamaha.com/en/support/manuals/index.html However there is no P160 should this read PSR160 in which case select this at the same link. Dan
5/3/2017 4:02:43 PM • Yamaha P95... • Answered on May 03, 2017
My yamaha p 95 .Only touch key (D-G-A)on Same time, will be more G # key Sound? What is the problem?
I have this problem too and it got worsened over time. Have you found a solution yet ?
2/8/2017 12:51:00 PM • Yamaha P95... • Answered on Feb 08, 2017
3answers
Hello- my P95 sustain pedal
This is confusing... you say "the sustain works when you disconnect the cord"? How can that happen? and doesn't work when it is plugged in.
MOST sustain pedal problems are due to people using a different pedal than the keyboard is designed to use. It is very common that someone tries to use a Roland sustain pedal on a Yamaha and oof course it doesn't work because the Roland pedal is normally closed and Yamaha usually requires a normally open contact.
A FEW keyboards now check the state of the pedal input when power is first turned on and configure the pedal polarity accordingly. For these keyboards, make sure the pedal is plugged in before power is turned on.
11/5/2016 8:05:08 AM • Yamaha P95... • Answered on Nov 05, 2016
How do I transpose on the yamaha p 105
You are probably trying to set the new pitch on the wrong octave. Try using the C above middle C as the center point.
10/27/2015 12:16:45 AM • Yamaha P95... • Answered on Oct 27, 2015
2answers
How do I get it to play in tune?
Take a look at this page from the user manual. 25779392-n3efj5hfs1j0bw2r01yldgte-3-0.jpg
8/14/2015 4:23:35 PM • Yamaha P95... • Answered on Aug 14, 2015
Sounding a half step too high
Use the factory reset Hold down highest white key whilst turning on This should return to factory settings - pitch should now be back at A440 If you need to adjust then see page 19 of the user manual where it explains fine tuning.
5/14/2015 2:51:39 PM • Yamaha P95... • Answered on May 14, 2015
P95 making noise when pressing any key or any sound. (piano,organ,etc.)
thats a motherbord problem./ ic called tone generator which is usually faulty.
10/17/2014 6:17:19 AM • Yamaha P95... • Answered on Oct 17, 2014
Some keys make no sound when played. How do you cprrect this?
try to clean under neath of those particular keys very gently with cotton buds .2)is it the case with in all the octaves 3) has the K.B been in humid places
9/30/2014 2:05:58 AM • Yamaha P95... • Answered on Sep 30, 2014
No sound
Take it to a tech... What are you going to do to fix it, hit it with a big rock?
4/17/2014 4:35:30 AM • Yamaha P95... • Answered on Apr 17, 2014
0answers
Out of tune
Be the first to answer 2/8/2014 6:52:02 PM • Yamaha P95... • Posted on Feb 08, 2014Be the first to answer
0answers
0answers
Service manual
Be the first to answer 1/25/2014 4:00:32 AM • Yamaha P95... • Posted on Jan 25, 2014Be the first to answer
0answers
MY YAMAHA P-95 PLAYS NOTES i DONT PRESS
Haha yes - I know the feeling...fingers are nowhere near the keyboard the "BANG!" a note or a cluster of notes happens out of nowhere! :) Easiest solution will be to take it in to our local Yamaha Dealer and have them clean the contacts. Dust and hair can get between the keys and cause all sorts of problems with the sensors/contacts. I have learnt to clean them myself using a photographic blower brush, and if you're daring, give it a go. If not - don't risk it :)
12/25/2013 2:51:31 AM • Yamaha P95... • Answered on Dec 25, 2013
0answers
Remove cover
Be the first to answer 12/23/2013 10:01:34 PM • Yamaha P95... • Posted on Dec 23, 2013Be the first to answer
0answers
0answers
Yamaha P95 Digital Piano Logo
53 questions posted
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Music
  • Yamaha Music
Most Popular Question
yamaha
  • Music
