20 Most Recent
Olympus Ds71 (4096 MB 10625 Hours) Handheld Digital Voice Recorder Questions & Answers
My WS-750 M froze and
Hello
If nothing appaears on its display, check the batteries; whether they are not loaded properly,[verify the polarity of batteries inserted]; are batteries are dead or Power ON switch is off.
After replacing the batteries, time set is necessary.
Check whether the abtteries are inserted properly first. If you have its user manual, the method is pictureised in it. Refer to it. If there is no display at all, and the batteries and in good condition, inserted properly according to polarity, and the power switch at its side is ON; the unit has been damaged. Check the contacts springs of battery contacts are rusty or dirty, clean it well first, and insert the batteries. If you haven't its user manual, send your email address to me by Fixya; I'll sedn the manual to you by return mail. OK.
My Olympus WS-802 recorder has a "down volume" issue, where it just won't work, I can't lower the volume
It sounds like the water damage may have caused the down volume button to malfunction. While it may be possible to fix the button, it would require opening up the device and performing some troubleshooting, which can be difficult if you don't have experience with electronics. I would recommend taking the recorder to a professional repair shop or contacting Olympus customer support to see if they can assist you with repairs. If the device is still under warranty, they may even be able to provide a replacement.
