20 Most Recent
Vivitek D510 Projector Questions & Answers
D510 color wheel error
The project turns on for only about 10sec and then shuts down and i get a color wheel error ??
My vivitek d510 projector lamp is not turn on.
You need to check the power supply feed to the lamp circuit and if this is workingg fine check if there is lamp reset- hours used. Also if the filter is blocked remove and clean, check the fan and also the connections/connectors in the mother board.If not there can be errors in the motherboard.
The lamp turns on for a second and you can see the
some projector are normal like what what you mention...you need to connect a video source like computer or sound system that have a video output going to your projector...because if you power on the projector with out a video source you see only what you mention the logo of the projector..
I need driver
download the driver and the neccessary information from the following link
www.presentationrentals.net
www.linuxquestions.org
www.multimediaforworship.com/dualmonitor
www.panda3d.org/forums/viewtopic
www.mtbs3d.com/cgi-bin/newsletter
www.tomshardware.com
Do I need drivers to set up this projector and
I am needing to verify
hi,
vivitek D510 supports 16:9 ( wide screen) format also. it uses 180w projector lamp.
ok
