20 Most Recent
Majesco Zumba Fitness (Kinect) for Xbox 360 Questions & Answers
Once we get to the
I have the same problem. Returned the game to the store and got another copy...still did not fix the problem. I called teh 1-800 number and they told me I needed clear the play area...again, this was not the problem. What is the FIX?
Wats is error c000009c
This means that there may be a problem with your kinect sensor. Go to http://support.xbox.com to find out more about this.
Zumba
You directed this question at me, but unfortunately I'm unable to provide you with a real solution at this time.FixYa has discontinued direct questions, so if you would care to repost your question, the repost will be visible to all members of the FixYa community. Hopefully one of them will be able to provide you with a real solution.Thank you for using FixYa.
After signing it won't go to DONE, so it is stuck. Help
It is best that you do not experiment much as there is a possibility that some error has crept into the system. Please seek warranty support after registering with the dealer or the nearest center as you are entitled before the set can get tampered as you stand to loose on this free support.
In the zumba fitness xbox360
There is an option to save the setting on the main menu. Manually save the settings before you turn the game off, and then load them when you turn it on.
My daughter '15' says the game I bought
This is not true. Any game for the Xbox 360 should be able to open regardless of internet.
However, some features of the game may only be accessible with internet.
My workout calendar went to
Go to your Xbox 360 Main menu. Go to system settings and select Console settings. Go to Clock, and select the right date and time!
My xbox360 will not read
That means your Xbox 360 is broken. If you send it in to Microsoft they will replace the disk drive and it will fix the problem.
We just bought the game
You might want to go back to the store you got it from and see if they will replace the problem disc. If that isn't the issue, maybe it would be a good idea to clean the inside of your Xbox out with a can of compressed air.
The same goes with me.
Does the ps3 start up. do you see anything on the screen. Check DVD of game Clen if needed. your lens in the ps3 may need to be cleaned. Check Amazon for a Blueray DVD lens Cleaner they run about 9.99.
