20 Most Recent Sentry Safe Qe4531 Firesafe Waterresistant Safe Questions & Answers
How to open sentry valueguard safe 1330 1744403
I do not claim to be an expert, however I recently opened a valueguard 1330 that had been sitting at work abandoned and forgotten for sometime. I used simple hand tools for this, this method is crude but it worked. The underside of the safe has a plug in it which is where the factory fills the safe with an insulation that sets and hardens giving structure and weight. I imagine there is a better way to remove the insulation but at this time i used a hammer. It looks much the same as chalk with a harder consistency, a minute or two of hammering broke up most of it which was then cleared out by hand. underneath is a plastic liner and the inner floor of the safe. Once again I just had hand tools at the time, I used a hammer and punch to perforate the steel in a circular pattern. once this was finished a few solid strikes should be enough to bust through. Please keep in mind a drill would have been optimal, also the hole needs to be large enough for you to put you arm in. On the inside portion of the door there is a cover over the lock assembly held in by one screw, on this safe it was a combination flat head 1/4" drive screw. With the cover plate removed you should now be able to see three plates on a central axis, each plate has a slot that needs to alined with the lock assembly for it to travel. This is incredibly easy when working by feel alone. With all three alined you should be able to turn the handle on the outside counter clockwise and open your safe. I hope this helps anyone not wanting to pay a locksmith or sentry, your safe should still be viable except for the arm sized hole. I would suggest a new safe. Enjoy!
8/11/2014 3:56:39 PM • Sentry Safe... • Answered on Aug 11, 2014
FOGROT MY COMBO
If you have the original paperwork from your purchase or registered your safe when purchased, you should be able to contact the manufacturer for a bypass code. There should be a serial number engraved (or sticker) on the exterior of the safe. Law Enforcement commonly uses this method of gaining entry with a search warrant.
4/8/2014 2:48:19 PM • Sentry Safe... • Answered on Apr 08, 2014
How to fix a s0607
I have a Sentry Model 1610 safe with an electronic lock. Entering the factory 5 digit code gives the green proceed light but the handle won't turn and the door won't open. How can I get the door open?
2/1/2014 2:03:08 AM • Sentry Safe... • Answered on Feb 01, 2014
Factory code for century safe
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech with the serial number
11/23/2013 5:47:35 AM • Sentry Safe... • Answered on Nov 23, 2013
0answers
2answers
Cannot open safe and I have changed the battery
If you removed batteries more than 1 or 2 times in a row, safe may revert back to a factory setting.
The factory number should be on your instruction sheet that came with the safe.
Contact Sentry for the factory safe number that came with your safe.
However, if the safe was not opening before you replaced the batteries it may be a faulty solenoid.
Terry Whin-Yates BA Hons (Criminology)
3rd Generation Master Locksmith
25+ Years Experience
BC Security License : B4227
604-773-5625
http://www.mrlocksmith.com/
4/27/2013 10:44:24 PM • Sentry Safe... • Answered on Apr 27, 2013
0answers
I need the turns for sentry safe 1330 i seen it on
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about your Sentry Safe at www.SentrySafeShop.com
12/22/2010 1:28:46 PM • Sentry Safe... • Answered on Dec 22, 2010
How do I open a waterproof fireproof small sentry safe if the lock doesn't fully unlock
Easy and fast to open with a rare earth puck magnet
Opening a sentry electronic safe with a magnet and ...
Reddit · r/lockpicking 10+ comments · 6 years ago It's not just locks. Arguably one of the most popular and ubiquitous pieces of access control hardware is vulnerable to this same attack. Can you open a mechanical dial lock with a rare earth magnet?? Jul 2, 2016 Recommendation on size of magnet for cheap Sentry Safe ... Feb 20, 2018 Does a magnet still work on sentry safe? : r/safecracking - Reddit Jun 12, 2021 YSK: Most electronic safes can be opened very easily. - Reddit Mar 14, 2022 More results from www.reddit.com
Open Electronic Sentry Safe in Seconds with Rare Earth ...
Mr Locksmith Training https://www.mrlocksmithtraining.com > open-electronic-... Open Electronic Sentry Safe in Seconds with Rare Earth Magnet · Dimensions: 3? dia. x 1? thick · Tolerance">Tolerances: ±0.004? x ±0.004? · Material: NdFeB, ...
3 Ways to Pick a Sentry Safe Lock
wikiHow https://www.wikihow.com > ... > Lock Picking Grasp the handle and wiggle the magnet until the safe opens. Hold the magnet at the top left corner with one hand and the safe's handle with the other. Slide ... ..
3/12/2024 5:13:40 PM • Sentry Home... • Answered on Mar 12, 2024
I need instructions for my sentry 1330
https://cdn.masterlock.com/sentrysafe/resources/pdf/manuals/Sentry-SLS-Old-Models-Instructions.pdf That is what downloads when you enter 1330 as the model number. If you Google sentry 1330 instructions, the google results pop up some questions and answers that may be of interest with you click the carrats beside the questions.
3/5/2024 7:17:04 PM • Sentry Home... • Answered on Mar 05, 2024
What are the cubic inches for my Sentry Valueguard 1330 safe #1623580?
Volume (in³): 2160 cubic inches If you want to measure the cubic inches of a container, measure the length, width, and depth in inches. Then multiply those numbers by each other. For example, if your container is 5 inches long, 3.5 inches wide, and 7 inches deep, your calculation will look this: 5 x 3.5 x 7 = 122.5 cubic inches. May 17, 2023 Cubic Inch Calculator https://www.homedit.com/calculators/cubic-inch-calculator/#:~:text=If%20you%20want%20to%20measure,x%207%20%3D%20122.5%20cubic%20inches Sentry Valueguard 1330 Safe Perfect for a home closet, office, etc... Outside dimensions: 22"x17"x17" Inside Dimensions: 14-3/4" deep 12" wide 15-1/4" tall Pic with water bottle is for size reference...
Safe - Sentry Valueguard 1330 for Sale in Clovis, CA - OfferUp
2/24/2024 10:37:04 PM • Sentry Home... • Answered on Feb 24, 2024
How can I change code to a sentry 6250 safe
What you have is one of there products. You need to go to the following web address they have an on line form you fill out and will provide u with an opening combination. https://www.sentrysafe.com/support/
1/24/2024 10:44:18 PM • Sentry Home... • Answered on Jan 24, 2024
My lock on my sentry 1100 safe was drilled out at the key hole. How do I get a new lock for it?
You just buy another one, they are 50 bucks new. Or contact Sentry Safe and see if they will sell you one. Or take it to a locksmith and they will order and fit one for 75 bucks.
SentrySafe® Official Site ' Gun Safes & Fire Safes
Sentry Safe https://www.sentrysafe.com SentrySafe offers a broad range of secure storage solutions to keep your valuables protected from unexpected perils, theft and more. View safes. ‎Safe Selector · ‎Fire & Waterproof Safe · ‎Check Your Electronic Fire Safe · ‎Contact Us To buy a new one. https://www.google.com/search?q=sentry+1100+safe ..
9/1/2023 4:39:46 PM • Sentry Home... • Answered on Sep 01, 2023
I have a sentry professional quality/ 6250 safe I have had it for over 20 years it's manual no key I can't remember combo and I no longer have manual.
You are pretty stuck with that scenario. With an electronic lock you can use a rare earth magnet to pull the locking bolt but with a manual dial safe, you can't do that. I can remember my business safe combination from 1987 to 2005. You can also write it down. Use a concrete saw or angle grinder and cut the back off it. ..
7/2/2023 3:32:10 AM • Sentry Home... • Answered on Jul 02, 2023
Sentry Safe Qe4531 Firesafe Waterresistant Safe Logo
Popular Tags
17 questions posted
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Sentry Home Security
Most Popular Question
fogrot combo
  • Home Security
