20 Most Recent
XFX GeForce FX 5200 Graphic Card Questions & Answers
My pc hang >>> help
when my pc running,its automatically hang.but i dont know whats the problem.my sound card,agp is building.now i want to sollution this problem.please help me.
Where to buy the other parts of the computer x2gen?
Effective November 16th, 2007, Computer World Solution, Inc. (trade name "X2Gen")
was declared a debtor under Chapter 11 of the United States Bankruptcy Code in
the Northern District of Illinois Bankruptcy Court. As of the effective date,
the Debtor's ordinary course operations have been discontinued.
The bankruptcy case number is 07-21123 and further information can be
obtained through the U.S. Bankruptcy Court Northern District of Illinois
Electronic Filing System, (
https://ecf.ilnb.uscourts.gov/). You can
view the
Petition that was
filed as well as the
Consent
which the company provided to the court.
All games was so slow
you might have to many programs running at the same time you are playing games putting to much strain on the CPU
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have
to check the details on your computer
click start all programs accessories system tools system imformation you will see all of your computers imformation from there another way of doing this
click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer if you see something running that you don
Can i install a ggeforce fx 5200in an hp a850y w/
As long as your PC has the proper pci, apg or pci-e slot then it shouldnt be a problem. You also have to look at the cards specs and make sure your PC has the right amout of wattage to power the card. Also make sure you have the right power connector inside the PC. I would think that card would have a 4pinn female molex connector. You should have an extra one inside your PC case.
Does splinter cell 4 work with geforce 5200 fx
It should work if you have other recomendations
Supported OS: Windows XP (only)
Processor: 3 Ghz Pentium 4 or AMD Athlon 3000 (3.5 Ghz Pentium 4 or Athlon 3500 recommended) - Game optimized for dual-processor-enabled computers.
RAM: 1 GB (1.5 GB recommended)
Video Card: DirectX 9.0c-compliant, Shader 3.0-enabled 128 MB video card (256 MB recommended) (see supported list*)
Sound Card: DirectX 9.0c-compatible (EAX recommended) ? PC audio solution containing Dolby Digital Live required for Dolby Digital audio.
DirectX Version: 9.0c or higher (9.0c included on disc)
DVD-ROM: 4x CD-ROM or faster
Hard Drive Space: 8 GB
Peripherals Supported: Mouse, keyboard
Multiplay: Broadband connection with 128 kbps upstream or faster
Hang
Hello Sir
Your problem is your PC hangs in between.
See, the problem may be due to RAM. Some times it happens that RAM does not synchronize and causes problem.This problem can be solved by changing your RAM. Avoid using two RAMs.Use a single RAM.Contact your Computer vendor.
Regards
Fixya Member abgog
I can't get my Geforce 6150 to output to the TV via s-video
There is an Fn key on most laptops that allow you to output the monitor to another screen also.
There is also a combination like F + 4 for some laptops. Make sure also that you have the correct cable plugged into the port on the laptop videocard.
OUT OF RANGE on monitor screen
you have to change frequency of monitor to work smoothly form display property.
Out of Range is frequency is not matching
To solve this, wwhile booting Press F8 to get advanced boot menu from that select "Enable VGA mode"
change the display properties
right click on desktop - Select properties - Settings - Advanced (from bottom) - goto monitor tab - change the frequecny to default. and restart the system normal mode
I am Facing Some Serious Problems with Every games..
its excess heat check the nvidia monitor if it exceeds 65-70 degrees celcius.Firstly take precautions turn off computer from main switch press power button for 5-10 seconds make your hand touch the surface of the unpainted metal part to discharge static, Remove card (Found in manual).If it seems quite hot you can remove the heat sink by pressing in the plastic clips on the bottom and dust it off with a medium paint brush, BECAREFUL OF THE POWER CORD. you could use compressed air and blow under the heat sink and see to dust it off
G5 tower 1.8 ppc dvi interface video card to x2gen 22"
I would suggest you upgrade the video card something like the card in this link! Please note it specifically states on the box that it is for Mac G5. You also need at least 512MB system memory and osX 10.3.6 or higher.
Cheers & Good luck.
GeForce FX 5500-picture flickers
assuming you have set your agp slot in the cmos settings to the primary graphics controller and already had the agp graphics slot driver installed for the motherboard, try using a driver from the nvidia web site if you are having trouble with the driver that came on the cd.
Use the VGA onboard graphics if you have any or fit your old card and click on the link below for XP Drivers
http://www.nvidia.com/object/winxp_2k_93.71.html
If you still have problems then you will have to try an ATI graphics card as it just may not be compatable with your make of motherboard
