20 Most Recent
Dell Latitude E4310 Laptop Computer (Intel CORE I5 520M 250GB2GB) (BLEA6VM1) PC Desktop Questions & Answers
On previoius Dell products ALT-PRNT SCREEN used to
Check if you have to press the
fn (function) key on your laptop before pressing Print Screen, you can tell if they are both the same blue color.
When you press ALT+Print Screen, you only capture the active window, when you
click print screen you capture the entire screen. Then you will have to
press CTRL+V on your keyboard to paste into paint. If you have windows Vista, you can
capture screen shots much more easily using the Snipping Tool included with Vista.
Here's a How to guide to refresh: (Ref:
http://graphicssoft.about.com/cs/general/ht/winscreenshot.htm )
- Press the Print Screen key on your keyboard. It may be labeled [PrtScn].
- Open an image editing program, such as Microsoft Paint.
- Go to the Edit menu and choose Paste.
- If prompted to enlarge the image, choose Yes.
- Optional: Use your image editor's crop tool to crop out unnecessary portions of the screen shot.
- Go to the File Menu and choose Save As.
- Navigate to the folder where you want to save the image.
- Type a file name for the image.
- Select a file type.
- Click the Save button.
Tips:
- Hold the Alt key down while pressing Print Screen to capture only the active window.
- Generally the GIF format works best when saving screen shots of application windows. The JPEG format usually makes screen shots (especially those with text) blurry, blotchy and discolored.
- See related resources below for more screen shot tips
and listings of screen capture software that offers many more options
for capturing screens and portions of screens on Windows and Macintosh
computers.
- The Windows "clipboard" is a term used to
describe the temporary storage space in memory where an item is placed
when you copy or cut. When you paste, the item is transferred to the
program you're working in. If you copy something else, the old item is
replaced with the new. You can't manipulate the clipboard directly; it's
only used for copy and paste operations.
Good Luck
How do I print screen
Hold "Fn" (left bottom of the key bord) press "End" (Actually print screen key) * pressing Fn means activate function keys.. Bye..
Find firewire 1394
if you are looking for a firewire port on the laptop, i believe it does not have one.. your option for connection would be the USB 2.0 and eSata port located at the left and right side of the laptop
Have a problem unlocking my dell laptop
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :-
http://www.hirensbootcd.net/ http://67.20.82.163/
Cant find any way to
It should be a key on your keyboard that has a sun logo on it. its most likley used in cunjuntion with a function key.
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
