20 Most Recent Kingston 4PK 4GB USB 20 DATATRAVELERI GEN 3 VALUE PK DTIG34GB4P (740617175844) Media Questions & Answers
Service india
Hi Virus or Trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert the pen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
4/6/2014 6:39:03 PM • Kingston 4PK 4GB... • Answered on Apr 06, 2014
CANNOT FORMAT MY 4GB KINGSTON PEN DRIVE..HELP...
Most of the time running a disk check first will fix your problem.
Right click on your drive's icon in "My computer"
Select properties. Go to the "tools" tab, select "check for errors".
Depending on the operating system you use, this could also be called "run scan disk", "run disk check" or "check for errors".
1/25/2011 4:43:03 PM • Kingston 4PK 4GB... • Answered on Jan 25, 2011
How to rename a Kingston 4gb memory stick
The exact procedure depends on your operating system, but changing the volume name is usually very similar to renaming a file, e. g., in a file browser window showing the mounted drives, you would right-click on the memory stick icon and select "Rename..." from the pop-up menu, or double-click on the volume name to enable editing it. Of course, you must have write permission for the entire volume. Note: In some OS versions, you may not be able find "recent files" opened from that volume before you renamed it; you'd have to browse directly to the memory stick instead of using the recent files shortcuts.
9/29/2020 5:47:28 PM • Kingston... • Answered on Sep 29, 2020
Kingston Data traveller USB password reset
Not knowing the model # makes it difficult to give you a difinitive answer. Kingston's support docs all say that after x mny failed logins the device will have to be formatted. The default # of failed logins seem to be 10. I think you're out of luck.
2/5/2019 5:18:37 AM • Kingston... • Answered on Feb 05, 2019
2answers
How do i fix corrupted usb flash drive?
formate it in you pc
2/12/2017 1:01:06 PM • Kingston... • Answered on Feb 12, 2017
My Kingston Micro SD 4 GB does not have the lock/unlock tab. My Nikon L110 camera tells me that the card is write protected. What do I do? Thanx! My e-mail address: [email protected]
bridge the gap where the tab should be with a small piece of tape this may do the trick.
6/5/2016 5:37:56 PM • Kingston... • Answered on Jun 05, 2016
My TransFlash 2.0 memory card doesn't show on my lap top
First, the basics... There are three kinds of SD cards (SD, SDHC and SDXC). Not all computers are designed to accept all three types. SD cards can store up to 2GB of data, SDHC can store up to 64GB of data, and SDXC cards can store up to 2TB (terabytes) of data. If you are unsure which types of cards your laptop or computer will accept, visit the manufacturer's web site and look for the specifications for your particular model to be sure. It's tempting to want to buy an SD card with a large data capacity, but it's wasted money if your computer will not work with the high capacity card. Make sure you have inserted the card correctly (and fully). The card is 'keyed' (with a notch in one corner) so it should only fit into the SD card slot one way *easily*. Obviously you can try to force the SD card into the slot the wrong way, but the position which goes in the easiest is probably the right way. Some devices have a symbol beside the slot indicating which way the card should be inserted. Be careful, though. It is natural to think the the card should be inserted with the manufacturer's label facing up, but I've seen devices where the card should be inserted 'upside-down', contrary to what I thought. If you are using a Windows computer with a 'recent' version of the operating system (Windows Vista or later), the computer should recognize the card (as a newly attached piece of hardware) and show the card as a new drive letter when you open the Windows Explorer program to view your files and folders. If the card is new, it should be formatted already and can be used immediately, BUT...your computer may need to have a driver program (software that enables the use of specific hardware items). My laptop, for example, uses a driver from Ricoh to enable the SD card slots, and that driver had to be downloaded from the HP support site and installed before my SD card slots would recognize SD cards. If you know you have the correct SD card device driver installed, have an SD card that will work with your computer but still do not see the card in Windows Explorer, you can check in the Windows Device Manager to check its status. You can also use the Disk Management features of Windows to check what drive letter has been assigned to the drive. If the SD card has been assigned a drive letter already used by another drive, then it will not be available in Windows Explorer. If you think any of these last problems I mentioned are part of your issue, reply here and I can see if I can help you further.
4/28/2016 2:06:03 PM • Kingston... • Answered on Apr 28, 2016
How do i remove write protection from a sd card
Take your memory card out of the device and switch the position of the "lock" tab. One position is for "locked" (i.e., "Write Protected") and the other position will allow the card to be written to (unlocked). NOTE: Some cameras have image protection built into the on-camera software and you may need to configure this there.
11/26/2014 9:50:23 PM • Kingston... • Answered on Nov 26, 2014
Usb is not bein format
Put your drive into a USB port on your computer. Right click on that drive after it appears in My Computer and select Format; set the File System drop-down to NTFS (better file storage space) or FAT32 (more compatibility in older operating systems) and click Start.
11/26/2014 9:43:17 PM • Kingston... • Answered on Nov 26, 2014
Not visible on computer
Your computer may need drivers installed for your flash drive. Visit your USB drive manufacturer's website, find the "Support" page, and download the drivers for your specific drive. Be sure to know what version of your operating system you are running as it may be necessary to ensure you get compatible drivers. Install the drivers and try again.
11/26/2014 9:41:09 PM • Kingston... • Answered on Nov 26, 2014
Formatear sd 4g
okay, problem isn't in ur pendrive problem in ur computer, some kind of viruses attack only removable drives, and user didn't find viruses in computer and also antivirus, you should download microsoft security essential here,--- http://windows.microsoft.com/en-IN/windows/security-essentials-download , and update this software insert ur pendrive and start virus scanning as a whole computer including ur pendrive ur problem will surely solve
6/27/2014 6:06:11 PM • Kingston... • Answered on Jun 27, 2014
Usb contents has strange symbols that the computer can't read
It sounds like your files are encrypted (for some strange reason). You will need to figure out how to un-encrypt or disable encryption on the troublesome drive. It might help further if you stated what OS's are on the computers involved.
6/22/2014 8:22:38 AM • Kingston... • Answered on Jun 22, 2014
3answers
Sounds like there are sectors of the drive are failing. Chkdsk can help mark those as not usable. If drive is old and problems persist then consider getting a new one.
4/25/2014 12:56:33 AM • Kingston... • Answered on Apr 25, 2014
I installed the memory upgrade in the new laptop and the laptop wouldn't boot. It powers on for a couple of seconds and shuts down. There are no beeps. The laptop already has a 4GB module installed, s
Brand, speed, voltage of original, Brand and model of laptop Brand, quantity,speed, voltage of upgrade
4/22/2014 11:58:17 PM • Kingston... • Answered on Apr 22, 2014
Micro sd adapter driver
"device driver software was not successfully installed" Find the correct driver for your computer and operating system.
4/7/2014 10:02:45 PM • Kingston... • Answered on Apr 07, 2014
Kingmax microSD cracked
Get a new one. Then read how to take care of it.
4/7/2014 9:58:04 PM • Kingston... • Answered on Apr 07, 2014
AWRDACPI usb driver
Can you tell more information about your USB driver? What your problem is? Data problem or unrecognized problem? Anyway try 4Card Recovery, which can solve all the situations above. How to Recover Photos Videos off SD Card after Formatting Unformat SD...
3/22/2014 2:59:00 PM • Kingston... • Answered on Mar 22, 2014
Bad sector at my flash memory
Run check disk and choose to automatically repair bad sectors.
1/20/2014 2:41:41 AM • Kingston... • Answered on Jan 20, 2014
Getting write error on Kingston 32gb Ultimate 600X Compact Flash Card
at the command prompt (pc/notebook) type chkdsk x: /f where x is your flash card
12/19/2013 11:45:35 PM • Kingston... • Answered on Dec 19, 2013
Kingmax sd card
To remove write protection: Open Start Menu >> Run, type regedit and press Enter. This will open the registry editor. Navigate to the following path: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies Double click the key WriteProtect in the right pane and set the value to 0 In the Data Value Box, press OK Exit Registry, restart your computer and then re-connect your USB flash drive to your computer.
12/19/2013 11:33:27 PM • Kingston... • Answered on Dec 19, 2013
Kingston 4PK 4GB USB 20 DATATRAVELERI GEN 3 VALUE PK DTIG34GB4P (740617175844) Media Logo
3 questions posted
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Electronics - Others
Most Popular Question
service india
  • Electronics - Others
