20 Most Recent Kingston 2PK 4GB USB 20 DATATRAVELERI GEN 3 TWIN PK DTIG34GB2P (740617175851) Media Questions & Answers
How can i download a music .save to my usb?
1. 1. Connect your USB Flash drive to your computer.You can do this by locating an unused USB port on your computer. 2. Locate the my computer icon on your desktop,provided you are running one of the various Windows operating systems. Doubleclick the my computer icon. You will see a drive labeled as removable drive orflash drive. Double click on the drive. Leavethis window open, proceed to next step. 3. 3. Locate the music files that you havedownloaded/save to your computer. Usually the default location will be "My Music" folder under "MyDocuments". Open the folder that you have downloaded/saved your music in. 4. 4. Highlight the music file and right click. Pickthe copy option. Next go back to the window you opened for you flash drive instep one. Right click in this window and click paste. You should now see yourmusic file in this window.
4/21/2020 9:26:31 AM • Kingston 2PK 4GB... • Answered on Apr 21, 2020
My attached 8 gb Kingston in neither opening not formating by window? Pleasse help me to format my usb
CIRCUIT PROBLEM....REPLACE WITH NEW ONE
12/20/2014 8:25:19 AM • Kingston 2PK 4GB... • Answered on Dec 20, 2014
Try another computer. If it does not format then it is defective. Get a new one. I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
12/6/2014 3:56:17 AM • Kingston 2PK 4GB... • Answered on Dec 06, 2014
Need instruction manual don't know how to use
An example on how to download and save to an External Hard Drive and copy and paste to an External Hard Drive Click start all programs accessories open windows explorer navigate to your data Right click on the data select copy navigate back to the External Drive. or right click on the data select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in or if you are downloading data from the internet. Once it starts downloading windows will ask whether you want to run or save it a browse option will open you can save it into your External Drive or a folder in my documents or another device or a usb device if you need more help with this post a reply Hope this helps
1/15/2013 5:26:28 PM • Kingston 2PK 4GB... • Answered on Jan 15, 2013
Hello, i am using a mac os x. how do i unlock a
Try reformatting it:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
4/20/2011 5:52:14 AM • Kingston 2PK 4GB... • Answered on Apr 20, 2011
My usb is unable to complete the format what
Hi and Welcome to Fixya
You may try to format your USB using the computer disk management tool. Right click on MY COMPUTER then select manage. Make sure that the USB is plug in to the usb port. Go to disk management then look for you Flash drive. Right click on it then click format.
Please reply if you have any questions.
Have a good one!
2/21/2011 4:55:30 AM • Kingston 2PK 4GB... • Answered on Feb 21, 2011
How to rename a Kingston 4gb memory stick
The exact procedure depends on your operating system, but changing the volume name is usually very similar to renaming a file, e. g., in a file browser window showing the mounted drives, you would right-click on the memory stick icon and select "Rename..." from the pop-up menu, or double-click on the volume name to enable editing it. Of course, you must have write permission for the entire volume. Note: In some OS versions, you may not be able find "recent files" opened from that volume before you renamed it; you'd have to browse directly to the memory stick instead of using the recent files shortcuts.
9/29/2020 5:47:28 PM • Kingston... • Answered on Sep 29, 2020
Kingston Data traveller USB password reset
Not knowing the model # makes it difficult to give you a difinitive answer. Kingston's support docs all say that after x mny failed logins the device will have to be formatted. The default # of failed logins seem to be 10. I think you're out of luck.
2/5/2019 5:18:37 AM • Kingston... • Answered on Feb 05, 2019
2answers
How do i fix corrupted usb flash drive?
formate it in you pc
2/12/2017 1:01:06 PM • Kingston... • Answered on Feb 12, 2017
My Kingston Micro SD 4 GB does not have the lock/unlock tab. My Nikon L110 camera tells me that the card is write protected. What do I do? Thanx! My e-mail address: [email protected]
bridge the gap where the tab should be with a small piece of tape this may do the trick.
6/5/2016 5:37:56 PM • Kingston... • Answered on Jun 05, 2016
My TransFlash 2.0 memory card doesn't show on my lap top
First, the basics... There are three kinds of SD cards (SD, SDHC and SDXC). Not all computers are designed to accept all three types. SD cards can store up to 2GB of data, SDHC can store up to 64GB of data, and SDXC cards can store up to 2TB (terabytes) of data. If you are unsure which types of cards your laptop or computer will accept, visit the manufacturer's web site and look for the specifications for your particular model to be sure. It's tempting to want to buy an SD card with a large data capacity, but it's wasted money if your computer will not work with the high capacity card. Make sure you have inserted the card correctly (and fully). The card is 'keyed' (with a notch in one corner) so it should only fit into the SD card slot one way *easily*. Obviously you can try to force the SD card into the slot the wrong way, but the position which goes in the easiest is probably the right way. Some devices have a symbol beside the slot indicating which way the card should be inserted. Be careful, though. It is natural to think the the card should be inserted with the manufacturer's label facing up, but I've seen devices where the card should be inserted 'upside-down', contrary to what I thought. If you are using a Windows computer with a 'recent' version of the operating system (Windows Vista or later), the computer should recognize the card (as a newly attached piece of hardware) and show the card as a new drive letter when you open the Windows Explorer program to view your files and folders. If the card is new, it should be formatted already and can be used immediately, BUT...your computer may need to have a driver program (software that enables the use of specific hardware items). My laptop, for example, uses a driver from Ricoh to enable the SD card slots, and that driver had to be downloaded from the HP support site and installed before my SD card slots would recognize SD cards. If you know you have the correct SD card device driver installed, have an SD card that will work with your computer but still do not see the card in Windows Explorer, you can check in the Windows Device Manager to check its status. You can also use the Disk Management features of Windows to check what drive letter has been assigned to the drive. If the SD card has been assigned a drive letter already used by another drive, then it will not be available in Windows Explorer. If you think any of these last problems I mentioned are part of your issue, reply here and I can see if I can help you further.
4/28/2016 2:06:03 PM • Kingston... • Answered on Apr 28, 2016
How do i remove write protection from a sd card
Take your memory card out of the device and switch the position of the "lock" tab. One position is for "locked" (i.e., "Write Protected") and the other position will allow the card to be written to (unlocked). NOTE: Some cameras have image protection built into the on-camera software and you may need to configure this there.
11/26/2014 9:50:23 PM • Kingston... • Answered on Nov 26, 2014
Usb is not bein format
Put your drive into a USB port on your computer. Right click on that drive after it appears in My Computer and select Format; set the File System drop-down to NTFS (better file storage space) or FAT32 (more compatibility in older operating systems) and click Start.
11/26/2014 9:43:17 PM • Kingston... • Answered on Nov 26, 2014
Not visible on computer
Your computer may need drivers installed for your flash drive. Visit your USB drive manufacturer's website, find the "Support" page, and download the drivers for your specific drive. Be sure to know what version of your operating system you are running as it may be necessary to ensure you get compatible drivers. Install the drivers and try again.
11/26/2014 9:41:09 PM • Kingston... • Answered on Nov 26, 2014
Formatear sd 4g
okay, problem isn't in ur pendrive problem in ur computer, some kind of viruses attack only removable drives, and user didn't find viruses in computer and also antivirus, you should download microsoft security essential here,--- http://windows.microsoft.com/en-IN/windows/security-essentials-download , and update this software insert ur pendrive and start virus scanning as a whole computer including ur pendrive ur problem will surely solve
6/27/2014 6:06:11 PM • Kingston... • Answered on Jun 27, 2014
Usb contents has strange symbols that the computer can't read
It sounds like your files are encrypted (for some strange reason). You will need to figure out how to un-encrypt or disable encryption on the troublesome drive. It might help further if you stated what OS's are on the computers involved.
6/22/2014 8:22:38 AM • Kingston... • Answered on Jun 22, 2014
3answers
Sounds like there are sectors of the drive are failing. Chkdsk can help mark those as not usable. If drive is old and problems persist then consider getting a new one.
4/25/2014 12:56:33 AM • Kingston... • Answered on Apr 25, 2014
I installed the memory upgrade in the new laptop and the laptop wouldn't boot. It powers on for a couple of seconds and shuts down. There are no beeps. The laptop already has a 4GB module installed, s
Brand, speed, voltage of original, Brand and model of laptop Brand, quantity,speed, voltage of upgrade
4/22/2014 11:58:17 PM • Kingston... • Answered on Apr 22, 2014
Micro sd adapter driver
"device driver software was not successfully installed" Find the correct driver for your computer and operating system.
4/7/2014 10:02:45 PM • Kingston... • Answered on Apr 07, 2014
Kingmax microSD cracked
Get a new one. Then read how to take care of it.
4/7/2014 9:58:04 PM • Kingston... • Answered on Apr 07, 2014
Kingston 2PK 4GB USB 20 DATATRAVELERI GEN 3 TWIN PK DTIG34GB2P (740617175851) Media Logo
8 questions posted
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Electronics - Others
Most Popular Question
download music save usb
  • Electronics - Others
