20 Most Recent Hitachi 50VS810 Television Questions & Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Hitachi 50VS810... | Answered on Apr 07, 2015
Hi, Heat is the enemy of electronics, and these sets operate hot. You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
If you wish to repair it yourself what type of electronic training do you have?
What type of TV test equipment do you own?
Do you own and know how to operate an oscilloscope?
If you decide this is not something that you can do I expect this repair will be about $250 to $450, depending on how many parts are found to be out of factory specifications, if the problem is a bad circuit board, and if the board can be repaired or has to be replaced. A small TV repair shop will often charge less for the repair than a large electronics repair facility.
Should you require further clarification, never hesitate to ask. It would be my pleasure to clarify my answer to your question. If after reviewing the above information, you have additional questions, I will be glad to answer them. My goal is your 100% satisfaction with all questions I answer.
Hitachi 50VS810... | Answered on May 25, 2011
if the picture is starting to look dim replace the lamp.
Hitachi 50VS810... | Answered on Feb 22, 2011
Yes. You will have to reset the lamp hours. It should be in your owners manual.
Copy and paste this link in your address bar if you don't have the manual:
50VS810
http://tv.manualsonline.com/manuals/mfg/hitachi/hitachi_projection_television_product_list.html
I have heard that this may work on your tv
1. Switch power ON, and press the TIMER button on the remote control transmitter, or the RESET button on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear on the lamp timer on the bottom of the screen.
2. Press the MENU button on the remote control transmitter, or the RESET button on the control panel, while the lamp timer is displayed. The 'LAMP xxxx [] -> 0 [|] CANCEL' message will then appear.
3. Press the [<|] and select 0, and wait until the timer display is cleared.
Hitachi 50VS810... | Answered on Sep 09, 2009
Replace the main board. Parts on eBay or internet.
Hitachi... | Answered on Sep 02, 2019
Check if there is a reset button on the back or located by the power button on your tv
hope this helps
Hitachi... | Answered on Aug 23, 2019
Main digital board fault. Check and replace it. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Hitachi... | Answered on Jul 14, 2019
i'd say it's a ghost or a psychic power or a force from outer space you better be careful those things are scary
Hitachi... | Answered on Jul 13, 2019
unplug. Press and hold power button 10-15 sec's then repower see if ok. Most tv's will go into standby if there is no signal detected.
Hitachi... | Answered on Jul 12, 2019
Televison & Video Logo
Popular Tags
8 questions posted
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
just replaced lamp in tv but now fan
  • Televison & Video
