20 Most Recent
LeapFrog Leapster Explorer Learning Game System (green) Questions & Answers
My son's Leapster Explorer suddenly
I had same problem, just fixed it by a little hack. The volume up switch is broken.
1. Remove accessory door on bottom. 2. Remove all screws on back. 3. Open back cover.
Looking at the exposed board, there are 2 volume switches (back to back). Directly next the switches are four contacts: the upper 2 are for volume down, the lower 2 are for volume up.
4. Place the battery pack on the board and hold it down. 5. Press the power button to turn on the unit. 6. Use a small wire to jump the volume up contacts multiple times to change the volume to maximum (or desired level). 7. (Optional) Remove the volume buttons and throw away the rubber cushions to prevent the volume from changing. 8. Replace everything back in place.
1/12/2014 3:12:04 PM •
LeapFrog...
Answered
on Jan 12, 2014
I gave my son a
there are three basic reasons why the leapster explorer won't bring out sound.
1. Defective speaker
The speaker of your leapster explorer maybe defective, this can make it not bring out any sound. Disassemble the leapster explorer, check the speaker part, test the speaker with a AA battery. If you hear any sound using the battery, then it means there is nothing wrong with the speaker.
2. Loose wire connection
Disassemble the leapster explorer, check the wires connecting the speaker to the board. Check for any wire cut, or loose connection which can cause the speaker not to bring out sound.
3. Sound IC/Card/Board
If non of the above is the cause of the problem, then it means the leapster explorer is having a defective sound ic/board/card. There is an IC on the board of the leapster explorer which is responsible for sound. If this ic has a shot, there won't be any sound. If this be the cause, I think it's high time to took the leapster explorer to a repairman because this requires skill.
I hope the above is clear. If not, please let me know for further assistance.
Regards.
8/10/2011 2:22:16 PM •
LeapFrog...
Answered
on Aug 10, 2011
Leapreader won't turn off
Try pressing the on/off button to turn it off. I had a same problem. I depressed the on/off button for ~6 second or so and the device turned off. When I turned on again, the LeapReader no longer had a white light and was recognized by my computer.
Leapfrog leappad won't turn off
my leap pad ultra is at that part of turning off wher their is only a dot of wite left on the screen.it is still doing that and it has been at least 2 hours since i played it. it wont turn on either now.i am a kid sorry if their are spelling errors
Leap reader won't turn on
the pen wouldn't launch from app on the desktop or turn on manually for me either, You need to launch it through their website, it's a rollover button top right on the website page 'Launch Leapfrog Connect' the pen then auto turns itself on!
