20 Most Recent BETTER CHEF 5-speed Stand/hand Mixer - Red Questions & Answers
How to change the belt in a Bodum electric mixer?
Question moved from Cars and Trucks. Stand Mixers don't normally have belts and I don't believe this one does as I can't find spare belts. They are operated by nylon cogs that run in grease. The most likely reason is the she shear pin has sheared. This is a small pin like a nail that goes through a cog or shaft and shears if too much load is put on the mixer beater or dough hook. It often happens if you make bread and have the speed too high. https://www.google.com/search?q=change+the+belt+in+a+Bodum+electric+mixer ..
3/5/2024 12:47:57 AM • Food Mixers • Answered on Mar 05, 2024
Harbinger LP9800 mixer keeps shorting out, what can we do? Its been happening for a few months.
You will need to get a qualified electronics technician to look at it. The issue could be anywhere on the circuit boards inside the mixer. Unless you know what you are doing don't try to repair it yourself as you could make the problem worse.
2/29/2024 4:34:11 PM • Food Mixers • Answered on Feb 29, 2024
On Dash stand mixer, the beaters are stuck and i can't eject them
Spray some WD40 into the eject button. The wait 10 minutes and turn it upside down and spray WD40 down the side of the beaters Leave 10 minutes and try again/ If that doesn't work, you will need full disassembly ..
1/28/2024 11:29:48 PM • Food Mixers • Answered on Jan 28, 2024
Manuel for Ultrex 14033 2 speed ice cream mixer
Please state whether user or maintainance manual.
1/25/2024 6:36:56 PM • Food Mixers • Answered on Jan 25, 2024
Kitchen Aid Mixer. How to fix a grinding sound when switch is on Medium speed?
Question edited for clarity. The drive train probably need cleaning and re-greasing, but there is also a gear that wears out. https://www.google.com/search?q=Kitchen+Aid+Mixer.+How+to+fix+a+grinding+sound+when+switch+is+on+Medium+speed ..
12/27/2023 12:43:20 AM • Food Mixers • Answered on Dec 27, 2023
How to replace the drive belt on a Bodum Stand Mixer 11381 and where do I get a belt for this machine in New Zealand?
Contact them direct. No one sells them online. Or most cities have a drive belt supplier. Take in the old one and say 'can I get one of these'. There are 8 places near me! https://www.google.com/search?q=drive+belt+suppliers+near+me
Food Mixer BISTRO Black - Kitchen Appliances
Bodum https://www.bodum.com > 11381-01us-3-bistro The food mixer BISTRO Black has a 7 speed motor up to twice the power of traditional stand mixers. Its attachments are also dishwasher safe. Bake in style! US$103.99 https://www.google.com/search?q=Bodum+Stand+Mixer+11381+belt ..
12/17/2023 4:48:08 AM • Food Mixers • Answered on Dec 17, 2023
After mixing bread dough the mixer head will not tilt up to get the dough out of the bowl
Push the head down before pressing the button on the mystery mixer. There is probably dough under the hook with it pressing the head up and is locking the catch. You can pull out the dough around the dough hook to make it easier. All questions need 'make model (what it is)', first 3 words please
11/25/2023 5:44:41 PM • Food Mixers • Answered on Nov 25, 2023
I lost the beaters for my JC Penney 10 Speed Cooks Hand Mixer (HM820)
I have extra beaters.
11/9/2023 4:25:32 PM • Food Mixers • Answered on Nov 09, 2023
Good substitute for "Sunbeam power unit lubricant"?
All question need full 'make model (what it is)' please. Duplicate question deleted. Press Refresh to see your question. The only thing we know it that is made by Sunbeam and it MAY be a food mixer because that is the category it is posted to. Look at what is there already. It is black and greasy, it will be GP Graphite Grease. If it is white and greasy, you can use white Lithium grease in spray or tube. If it looks like normal oil, use 3 in One. This is a service manual for a vintage mixer, it say to use a special grease, but from the description high temperature bearing grease would work. https://studylib.net/doc/25985112/instructions-for-servicing-vintage-sunbeam-mixmasters Nothing based on the the quoted words. https://www.google.com/search?q=Sunbeam+power+unit+lubricant ..
11/5/2023 9:45:28 PM • Food Mixers • Answered on Nov 05, 2023
Thunderbird ARM-02 20 Qt. Planetary Mixer Bench-Type Mixer. I can't open the guard on my Thunderbird ARM-20?
Question edited for clarity and toss in some CAPS. Remove the bowl. Push it upwards and turning at the same time to centre it. Or remove all the screws, drop it down, clean it and put it back. https://www.google.com/search?q=thunderbird+arm-20+remove+guard ..
11/3/2023 5:52:23 PM • Food Mixers • Answered on Nov 03, 2023
2answers
My Kitchen Aid mixer flashed a spark and banged whilst I was using it. The plug fuse has not blown but the mixer does not work.
Could be anything, but could be the switch, the electronics board, motor windings, the carbon brushes or worn insulation somewhere. Odd that the plug fuse didn't blow. It needs electrical diagnosis to find out what went wrong.
Service & Support Owners Center
KitchenAid https://www.kitchenaid.ca > en_ca > service-and-support Make an appointment from our preferred list of service providers for service on your major appliances. ... Pro LineĀ® Series Stand Mixers Stand Mixer Attachments ... ..
10/11/2023 6:51:17 PM • Food Mixers • Answered on Oct 11, 2023
Ankarsrum Assistent Stand Mixer. The On / Off switch has stopped working. Where can I get a replacement part and troubleshoot this?
Question edited for clarity. There isn't much in the way of parts advertised, but the company is still in business https://www.google.com/search?q=Ankarsrum+Stand+Mixer+parts You may have more luck with the Electrolux version https://www.google.com/search?q=Electrolux+Kitchen+Assistant+parts ..
9/26/2023 6:44:42 PM • Food Mixers • Answered on Sep 26, 2023
The lever to lift the blade does not work
Videos that may help, but it is probably a repair centre job. https://www.google.com/search?q=Cooks+stand+mixer+lift+lever+repair ..
9/24/2023 1:27:04 AM • Food Mixers • Answered on Sep 24, 2023
Crypto peerless mixer EL 12 lights up but wont work
8/8/2023 8:41:03 AM • Food Mixers • Answered on Aug 08, 2023
Blakeslee A717 Commercial Mixer With 7 Quart Bowl. The snap ring on the dough hook doesn't hold.
It is not a make I have heard of before, which is odd, because I spent 50 years in catering and hospitality. Parts are available according to this. Getting to the snap ring would be the issue. You may be able to pull the old one out with a right angle pick and push the new one in. https://www.google.com/search?q=blakeslee+a717+parts ..
7/2/2023 11:24:15 PM • Food Mixers • Answered on Jul 02, 2023
Stand cake mixer not working. No power when turn knob think water got inside. You think a fuse is out or something? Can it be fixed?
If your stand cake mixer is not working and you suspect that water may have entered the device, it's possible that a fuse or other electrical component may have been affected. Here are a few steps you can take to troubleshoot and potentially fix the issue:
  1. Unplug the mixer: As a safety precaution, unplug the mixer from the power source before attempting any troubleshooting or repairs.
  2. Let it dry: If water has indeed entered the mixer, allow it to dry thoroughly before attempting to use it again. Place the mixer in a warm and dry environment for a few days to ensure all moisture has evaporated. Do not attempt to use the mixer while it is still wet, as it can be dangerous.
  3. Check for visible damage: Once the mixer is dry, carefully inspect the external components for any visible signs of damage, such as burnt marks or loose wires. Pay close attention to the power cord and the area where it connects to the mixer.
  4. Check the fuse: Some mixers may have a fuse that protects against electrical issues. Refer to the user manual or consult the manufacturer's website to determine if your mixer has a fuse and its location. If the fuse is accessible, check to see if it has blown and replace it if necessary. Use the recommended fuse rating specified by the manufacturer.
  5. Seek professional help: If the above steps do not resolve the issue, it's advisable to contact the manufacturer's customer support or consult a qualified appliance technician. They will have the expertise and knowledge to diagnose and repair any internal electrical problems safely.
6/28/2023 2:58:09 AM • Food Mixers • Answered on Jun 28, 2023
I have a John Deere La 130 with a 21hp Briggs and Stratton and I have been turning the gas shutoff solenoid for 20 minutes and it turns but doesn't seem to be coming off!
The gas shutoff solenoid on your John Deere LA 130 is typically located on the bottom of the carburetor bowl, and it should be screwed in to secure it in place. If you have been turning the solenoid for 20 minutes without it coming off, it's possible that it may be stuck or there could be another issue preventing it from loosening. Here are a few things you can try: 1. Apply penetrating oil: Spray some penetrating oil (such as WD-40) around the base of the solenoid where it screws into the carburetor bowl. This can help loosen any debris or corrosion that may be causing it to stick. 2. Use a wrench or pliers: If the solenoid has a hexagonal base, you can try using an appropriately sized wrench to provide additional leverage for turning it. Alternatively, you can use pliers to grip the solenoid tightly and turn it counterclockwise. 3. Seek professional help: If the solenoid still doesn't come off after attempting the above steps, it might be best to consult a professional technician or take your mower to an authorized John Deere service center. They will have the necessary expertise and tools to diagnose and resolve the issue safely. Remember to exercise caution while working on your mower's carburetor and ensure the engine is turned off and cool before attempting any repairs.
6/20/2023 4:31:53 PM • Food Mixers • Answered on Jun 20, 2023
How to get mixing bowl to release for removal please?
Question edited for typo. Two person job. Spray the locking lugs with WD40. One person holds the machine and the other turns the bowl anticlockwise. Full 'make model (what it is)' is useful in these questions. ..
5/11/2023 9:15:04 PM • Food Mixers • Answered on May 11, 2023
BETTER CHEF 5-speed Stand/hand Mixer - Red Logo
2 questions posted
Top BETTER CHEF Food Mixers Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a BETTER CHEF Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
  • BETTER CHEF Food Mixers
Most Popular Question
dash stand mixer beaters stuck eject
  • Food Mixers
