20 Most Recent Apple InFocus X1 Multimedia Projector Questions & Answers
Infocus X1 lighting problem
Well there are only a couple of things that could cause this problem. However considering this all started when it was mounted consider the possibility you may have used screws that are too long and are is/are subsequently shorting something out.
Cheers
12/30/2009 12:44:33 AM • Apple InFocus X1... • Answered on Dec 30, 2009
In focus x1 lamp strikes intermittently.
if you don't hear a high-pitched whir, or you hear chirping or buzzing, you have a bad colorwheel. the lamp won't light if the colorwheel won't spin. another way to check the colorwheel: rmove the lamp and lamp door. there is an opening above the lamp housing with a silver switch actuator in it. use a small screwdriver and gently press it in until you hear it click and turn the projector on. in the small opening inside the lamp housing, you should see colored glass. if it spins whith a high-pitched whir, it works fine. if not, it's bad and you may have a ballast issue. while you're in there, make sure both fans work. if they don't, vthe high heat may be tripping the temp sensor. next, check the lamp. is there dust on the screen on the side of the lamp? if so, excessive dust and heat have shortened the life of your lamp. blow out the dust with canned air. lastly, if the colorwheel, fans, and lamp are ok, you have to replace the ballast/power supply board. the bad news: there are no longer parts available for the x1. you could try finding one on ebay that has a different issue and swap out parts. if you have an x1a, you're in luck. those you can get parts for.
12/29/2009 9:06:04 PM • Apple InFocus X1... • Answered on Dec 29, 2009
INfocus X1 does nothing after bulb replacement
first off, make sur you have the right lamp (sp-lamp-009, 2 white wires. not the sp-lamp-018, one white, one red. the wires are in different locations in the plug). if you don't hear the colorwheel whirring, that'd be the next step. however, you cannot buy just the colorwheel. infocus does not sell individual parts of the optical engine. but that wouldn't matter, seeing as how they don't sell the engine anymore. also make sure the lamp door is completely closed. there is a peg on it that activates a switch to let the projector know it's closed. if you remove the lamp and use a flat-head screwdriver to activate that switch, turn on the projector. look inside the lamp housing and see if the colorwheel spins. if not, i think you need a new projector. if it does, check the fans. they can be replaced.
9/4/2009 5:42:32 PM • Apple InFocus X1... • Answered on Sep 04, 2009
Your comments
you need to replace the controller eca (main board)
9/4/2009 1:47:33 PM • Apple InFocus X1... • Answered on Sep 04, 2009
Silver thing fell out of X1 Infocus Projector What is It?
yes indeed. that is the colorwheel. it spins and sincs with the dmd chip to give you color and an image. unfortunately, infocus does not sell individual parts for the optical engine. you will need to replace the entire engine (which is almost $2000). time to get a new projector.
9/4/2009 1:43:50 PM • Apple InFocus X1... • Answered on Sep 04, 2009
3answers
Dear sir, i have a
I suggest you contact Full Compass for projector needs. Good luck
7/10/2009 9:08:10 PM • Apple InFocus X1... • Answered on Jul 10, 2009
0answers
The bulb works but I can't get an image
is the projecting image black or what??
what is being projected actually??
have you checked the lens section?
8/11/2008 6:35:57 PM • Apple InFocus X1... • Answered on Aug 11, 2008
Infocus X1 Projector
Thank you for your immediate reply. I could solve by myself. The problem was with power supply cable.
With regards
Gomohan
8/5/2008 1:59:01 PM • Apple InFocus X1... • Answered on Aug 05, 2008
Apple InFocus X1
It seems like your main card is not functioning.
pls check :
1. Color wheel is rotating or not.
2. Recheck Main card connectors.
mail me for any changes
Viren
7/16/2008 1:44:26 PM • Apple InFocus X1... • Answered on Jul 16, 2008
Are your hdmi wireless extenders apple compatible?
Consider the HRpart Wireless HDMI Display Adapter. Here are the key details: 4K Screen Mirroring: This adapter allows you to view audio, video, and office documents from a small device (like an iPhone, iPad, or MacBook) on a larger screen (TV, monitor, or projector) without messy cables. It's perfect for presentations, meetings, and exhibitions. Wireless and Easy Connection: Setting up this wireless HDMI adapter is straightforward. You'll need a 5V/2A power source (which can often be provided by a USB port near the HDMI input on modern TVs and projectors). If the port is occupied, a battery pack can also work. No Need for Wi-Fi: The adapter is self-contained and doesn't require an internet connection. Once connected to an HDMI input and powered, it displays a helpful screen for easy connection. You can stream movies, videos, games, and office files from your Apple device to a high-definition TV or projector. Compatibility: This device is more suitable for Apple devices, including iPhone models (such as iPhone 7 Plus, iPhone 8, iPhone XS, etc.), MacBook Pro, MacBook Air, and various iPad models (iPad Pro, iPad Air, iPad mini). However, please note that it does not support HDCP-protected applications like Netflix, Amazon Prime Video, Hulu, and others. You can find this HRpart Wireless HDMI Display Adapter on Amazon 1. Keep in mind that it's designed specifically for Apple devices and provides a convenient way to mirror or cast your screen wirelessly.
11/19/2023 5:44:49 PM • Apple Office... • Answered on Nov 19, 2023
Oce tds 860 error code 01101
Check if the fan on the Op panel side of the machine is running. Ensure the intake on left hand side of machine isn't blocked. Ensure rear vent on right hand back of machine is not blocked.
4/25/2019 2:44:15 AM • Apple Office... • Answered on Apr 25, 2019
WiFi connected to Apple MacPro
Have you set up the printer to print wireless? If so, if you have the computer and printer setup to work together, you should be able to turn the printer on and leave it on and print one job at a time. After it prints one job, it will stop and just be ready and waiting for you to send the next job. No need to turn off between jobs.
3/19/2018 1:50:46 AM • Apple Office... • Answered on Mar 19, 2018
,Printout has white horizontal streaks using win10 or my mini iPad, printer ok using Apple computer, while printing text. Color cart. Showing low ink, but was just replaced
When the ink is run past low (to empty) the print head can get damaged. You can also try 2 consecutive DEEP CLEANINGs .. See 'maintenance' in printer driver under advance setting s
1/6/2018 5:28:51 AM • Apple Office... • Answered on Jan 06, 2018
Why my pc is switched on but the monitor screen is blank?
Was the monitor turned off separately from the computer? The monitor does have it's own on/off switch. If it's all connected to a surge protector both would normally turn off at the same time.
10/21/2017 4:45:51 PM • Apple Office... • Answered on Oct 21, 2017
How can I connect Apple Mac to printer via new BTHub5-7XH2?
I suggest connecting the ethernet port on your Mac to the router and the router to your printer. You don't mention what printer you have (that would have been helpful) but I'm assuming it is networkable. Otherwise bypass the router and use a USB cable to connect it directly to your Mac in the usual fashion.
7/25/2016 10:53:27 AM • Apple Office... • Answered on Jul 25, 2016
Apple InFocus X1 Multimedia Projector Logo
11 questions posted
Top Apple Office Equipment & Supplies Experts
k24674
Kolbrun...
bvmihai
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Office Equipment & Supplies
Most Popular Question
infocus x1 nothing after bulb
  • Office Equipment & Supplies
