20 Most Recent Hitachi 61SWX10B 61" Rear Projection Television Questions & Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Hitachi 61SWX10B... | Answered on Jun 29, 2017
Hi Ellie!
Maybe in the manual you can find any information how to resolve this problem.
On this page of the manual there are shown most common receprion problems: http://manualsbrain.com/ru/manuals/979781/?page=72
Hitachi 61SWX10B... | Answered on Apr 26, 2017
Double picture (ghosting) is caused by the convergence circuit failing or a bad antenna connection.
Hitachi 61SWX10B... | Answered on Jan 29, 2016
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you check the site in Timeslide option, which can be selected from the dropdown list at the top left side of the display window, it will make search easy. Details about convergence adjustments have been described with illustrations.
Hitachi 61SWX10B... | Answered on Apr 23, 2013
TURN IT OFF AND DO NOT TRY TO USE---if a thin line left to right in middle of screen it is vertical problem---the set should shut down but even seconds count here--this can burn a mark on all three picture tubes instantly and it is permanent.
Problem if small line left to right in vertical circuit.
Let me know what you know and I will try to help--I know these sets very well.
SD TECH
Hitachi 61SWX10B... | Answered on Dec 30, 2012
Try to Google the model number, about the only way I can think of to find this information. It was at least 2,000 at one point.
Hitachi 61SWX10B... | Answered on Dec 22, 2012
Very common problems for DLP tvs,will get worst as times go by.Tv probally have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B unlevel on the pictures?Crooked pictures have mis colors alignments?Yes.There is no way manually to do an adjustment to fixed for this.Try push the tv remote button that said Magic Focus button.If the tv have data processing never completely done and have a error message and stop.Ur tv 100% have a dead tv convergence board,the tv convergence board must have it parts to be replaced like 2 STK convergence ICS and some or all of it resistors too.Than tv will be able to run the tv remote Magic Focus again to have a 100% data processing with no error message,tv to fixed this problems.The shop will cost u like $300-350 for parts and labors.
Hitachi 61SWX10B... | Answered on Aug 23, 2011
You will need to replace Both of the Convergence ICs ,Located on the left hand side board in back of TV. They are Big Black ICs and will have the part Number on them STK392-110 use the 120s.
Mats has ICs ,but tell them you want the convergence Kit for your Model it will have ICs and Resistors that come with it. ,You will also need to check Low Ohm resistors in the same circuit.
Mats Electronics 1-800-628-1118
PS. What ever you do (DO NOT) Clear the DC Ram if you do, it Takes over 6 hrs to realine convergence.
Hitachi 61SWX10B... | Answered on Aug 21, 2011
There is most likely an issue with the Surround PWB since you have the DP17 chassis. I would check the following items on the surround board. I have seen them all several times with the DP17
IT02 Shorted, pins 92 and 93 caused by Solder splash. IT02 Is also known to fail. Also pins 42, 43, & 44 have been known to have cracked solder
IT05 pins 20 & 21 shorted also Seems to have been caused by too much solder.
IS13, pins 1 & 2 shorted ( too much solder
Also check for cracked circuit trace patterns under IT05If you need further assistance let me know.
Hitachi 61SWX10B... | Answered on Jun 04, 2011
http://www.tvrepairkits.com/xcart/home.php?cat=1600
Here you go, figured I'd just give you the best link for the EXACT kit you need. (includes step-by-step picture instructions)
Please rate if this helped :)
Hitachi 61SWX10B... | Answered on Mar 28, 2011
your convergence ics are going bad.
Hitachi 61SWX10B... | Answered on Mar 22, 2011
The convergence repair kit for your model is available at www.tvrepairwporld.com which should solve that problem. The kit does include the parts and the CD with instructions for the repair.
Hitachi 61SWX10B... | Answered on Feb 18, 2011
You need to get into your menu and find where you can reinstall factory settings, or default settings. Also you can try the realignment......
Hitachi 61SWX10B... | Answered on Feb 10, 2011
how do i access the convergence on my big screen
Hitachi 61SWX10B... | Answered on Feb 08, 2011
Ur tv have a problems known as a convergence problems it dead.Tv have colors lines like R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Tv have a dead convergence board,board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to solved the tv picture convergence problems.The shop,will coat u like $300-350 for parts and labors.
Hitachi 61SWX10B... | Answered on Jan 31, 2011
Hitachi 61SWX10B 61" Rear Projection Television Logo
115 questions posted
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
picture unstable jittery colors
  • Televison & Video
