20 Most Recent Hitachi 50UX58K 50" Rear Projection Television Questions & Answers
During a rainstorm the electric
see the indicator of your tv. if it is glowing then any of the IC may be gone bad. if not u need to check the power supply. these tvs has very complicated schematic diagrams.
8/25/2011 9:46:32 AM • Hitachi 50UX58K... • Answered on Aug 25, 2011
My picture was fine until
Your convergence has failed and need to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed.
You can get the parts and instructions from www.TvRepairKits.com
4/25/2011 12:24:37 AM • Hitachi 50UX58K... • Answered on Apr 25, 2011
I have a Hitachi 50UX58B tv. The power was
This model has a known issue with two parts that fail. You can get the parts and instructions to fix it yourself from www.TvRepairKits.com
4/22/2011 3:38:22 AM • Hitachi 50UX58K... • Answered on Apr 22, 2011
I was playing a video
There is a common problem on this model, there is a capacitor that pops out----a visual look at it will tell you if the problem is it, it will have a physical crack in it. This set uses orange colored pico fuses---look like a little resistor and if the cap went it took one of them out. I can tell you where to look for the cap and the fuse associated with it. Total parts cost if this is what is wrong is under 10 dollars. It does require soldering (fuse and cap each have two leads) but not impossible to do for a do it your self person---this is so common I carry both the cap and fuses when I go to peoples homes---seen it bad in over 40 sets of this age, including one I own. If this told you something you did not know and you want to know where and what to look for, rate this solution as very helpful as I do this here for free. SD TECH
9/7/2010 10:09:18 PM • Hitachi 50UX58K... • Answered on Sep 07, 2010
5answers
Dark picture
Ok, this is no doubt a problem in the "Brightness: area. IF the set wasn't as old, sometimes a control on the main Board, could be adjusted, this would increase the voltage to the CRT drive, and "Brighten" the Picture. However with the set being 10 years old, the components would have aged so much, that I doubt, that it would have any effect. As it would only lift the picture by say a dB or a dB&1/2. If a Picture is VERY dark, say -3dB as I suspect yours, is, say, -3dB, that would be about 1/2 the usual brightness. I have no doubt that the components in and around this circuitry, have become faulty. It also may be that the Switchmode power supply, also may be involved, it may have failed, on that voltage "Rail" and be supplying insufficient current, to make the circuit function properly. It may even, be you CRT "Emission" may have failed somewhat and it is on the "Way out". Due to the age of the set, and the type of problem, you have. In my professional opinion, it may be time for a New unit. In my shop, a repair such as this, regardless, and especially, if it is a whole new CRT, then the cost is going to be quite high. I would recommend that you put the money, that you would spend on a repair, towards a new unit, with a long term warranty. You see, even if you "Fix" your existing problems, a 10 yo, set, is still, a 10 yo, set, and will, now, more than ever, will be prone, to break down again, according to the statistics, for units of that age, 72% of all "Repaired" items, fault again, within the next 12-18 months, usually fatally.. If you do entertain the idea of repair, you need to contact, an Hitachi, local office, and ask for a referral, to an authorised service center. you see at an "Authorised" place, they work on the brand name units all the time, they usually have original parts at hand. they are ALWAYS less expensive. They are honest.. You should then ask for a "Quote" for the repair, before proceeding with any work, this way too, you can make up your mind as to repair or replace. I do not recommend that you DIY, if only for the type of fault, that you have, and, the prospect, of spending good money after bad, trying to narrow it down, if at first one doesn't and fix it. Also it is in a high voltage area, and considerable skill is required there. I have included a link for a user manual. Below is a thing called a service manual, I couldn't find an exact one for your unit, but, it will give you the idea of whats required to attend to matters like this, it;s what us engineers use to troubleshoot and repair. have a read...
http://www.epanorama.rackhost.net/schematicsforfree/Video/Products/Samsung%20HLN5065W.zip
Below user manual. www.devicemanuals.com/.../Hitachi/Hitachi-50UX58K-User's-Guide-TVRVM05EZz.html -
6/28/2010 7:53:55 AM • Hitachi 50UX58K... • Answered on Jun 28, 2010
Shadows and not so bright picture
Convergence is the problem. You can get instructions and parts frow www.TvRepairKits.com
4/18/2010 2:37:01 AM • Hitachi 50UX58K... • Answered on Apr 18, 2010
Troubleshooting
On this model there is a common failure with some capacitors and fuses. Its a simple fix if you know which parts to use/avoid and how to do the repair. You can get complete instrucitons and parts for your model from www.TvRepairKits.com . Their kits include step by step color instruction guide as well as the correct parts to fix this issue.
4/18/2010 2:36:21 AM • Hitachi 50UX58K... • Answered on Apr 18, 2010
Was watching tv and power
Hi
Thanks for using FixYa. You’ll need to reset the Projection TV and to reset it follow these steps:
  1. Turn off the television and wait for 5 minutes.
2. After 5 minutes unplug the television power cord from the electrical outlet.
3. Let the television remain without power for more then 1 minute.
4. Plug the power cord back into the electrical outlet. If the television is plugged into a power surge protector, remove it from there and plug it directly into the wall outlet. Turn on the television. If the issue is resolved, then the problem is with the power surge protector and not the television.
If the issue is not resolved then this might have happened due to over-voltage. Please check the power supply unit for swollen/bulged capacitors and burnt wires/components on the power supply board of your TV. You should try and turn off the TV for 8-10 hours to reset it. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
4/11/2010 4:23:37 PM • Hitachi 50UX58K... • Answered on Apr 11, 2010
PICTURE NOT AS BRIGHT AS I WANT HAVE TRIED ALL .
Unfortunately there are 2 IC's and a capacitor that can cause this set to be really dark. Without proper troubleshooting it is impossible to diagnose. Have a shop check it out for you. Thanks
10/28/2009 2:54:01 AM • Hitachi 50UX58K... • Answered on Oct 28, 2009
The +[-] 120v (Green light) does not come on at
You most likely have an open fuse on the power supply in the 120v line. That means in most cases your horizontal output transistor is shorted. If it is look around the transistor itself and look for any ceramic disc capacitors that may be cracked or split. If I remember correctly I had a few of those models where I think it was C777 that was basically arcing which opened up the fuse and or shorted the transistor too.
10/17/2009 5:52:07 AM • Hitachi 50UX58K... • Answered on Oct 17, 2009
Model 50UX58K - picture has distortion &
Hi, if the shadow is colored lines then you probably need the convergence ICs and possible reisitors near them replaced .
If the shadows is just like a ghost of the image or a bar from top to bottom, then check if it does it on every input (dvd for example) , there are blanking bars that you can't see past the edges of the picture and when you have a bad cable signal you can see the ghost of the blanking bar sometimes. if it does it does not show the shadow when watching a DVD then its a signal issue with your cable/satelitte .
If your convergence is the issue, try the adjustments first and if that doesn't correct it, you can replace the ICs using kit # x480293 or stk392-110 (2 ICs) soldered in very technical for even a technician.
repairman cost about $250-$350
hope this helps
Eric I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
9/1/2009 7:49:46 PM • Hitachi 50UX58K... • Answered on Sep 01, 2009
2answers
LOST REMOTE TO TV (50UX58K) WILL REMOTE MODEL
is it a universal remote?
8/24/2009 2:34:32 AM • Hitachi 50UX58K... • Answered on Aug 24, 2009
Horizontal lines on hitach 50ux58k
This is a comb filter problem, you would need someone who can solder out the board or can and replace the caps and replace the board. It can be, depend what your service center labor is.
2/10/2009 12:27:52 AM • Hitachi 50UX58K... • Answered on Feb 10, 2009
The picture seems to be blurry or out of focus
thats how mine is. I don`t know who to ask how to fix it.
1/26/2009 10:50:55 PM • Hitachi 50UX58K... • Answered on Jan 26, 2009
Hitachi 50ux58k
You can get the parts from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix the following models (50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B).
11/2/2008 4:51:26 AM • Hitachi 50UX58K... • Answered on Nov 02, 2008
Hitachi 50UX58K-V8F001238
our hitachi did the same thing. It cost us 300.00 to tell us that there were two bad solder joints and they caused a power surge or something.
10/9/2008 10:29:31 PM • Hitachi 50UX58K... • Answered on Oct 09, 2008
2answers
Look in the instruction manual for troubleshooting. Also, try calling customer support. If it really still works fine, i would mind it. But since the tv is 10 years old, i would accept the fact that maybe it is time to get a new tv or repiar it.
5/4/2008 1:22:15 AM • Hitachi 50UX58K... • Answered on May 04, 2008
Hitachi tv shuts off . When I turn on the TV iMessage says please wait then turns off two seconds later.
That sounds like it is not booting properly. I would check for correct power supply opperation and if not that, look for a software reloading procedure in the user instruction manual.
2/11/2024 9:04:18 AM • Hitachi... • Answered on Feb 11, 2024
HI MY NAME IS MAZEN FAHMY I haVE DIODE T3D 36 THIS ZENER & DIODE 2 AND THIS IS IN DATA SHOW HITACHI CP-X3030WN FIX POWER.
https://www.google.com/search?q=DIODE+T3D+36 https://www.google.com/search?q=HITACHI+CP-X3030WN
Original Projector Ballast Main Power Supply For Hitachi ...
AliExpress https://www.aliexpress.com > item Original Projector Ballast Main Power Supply For Hitachi CP-X3030WN. 1/1. 1. US $52.62. Price shown before tax. Free shipping?Free returns. Original Projector ... US$52.62
Projector Power supply For CP-X2530WN CP-X3030WN ...
AliExpress https://m.aliexpress.com > item Projector Lamp Ballast And Power Supply For Hitachi CP-X2530WN. US $80. Projector Lamp Ballast And Power Supply For Hitachi CP-X2530WN. EUC 215g N/T05 ... US$50.00
CP-X2530WN/CP-X3030WN CP-WX3030WN
Projector Central https://www.projectorcentral.com > pdf > projecto... power supply make the projector turn on. Setting up. ?This product is also designed for IT power systems with a phase-to- phase voltage of 220 to 240 V ... 118 pages ....
12/5/2023 2:26:21 AM • Hitachi... • Answered on Dec 05, 2023
Televison & Video Logo
20 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
playing video
  • Televison & Video
