20 Most Recent Hitachi 57UWX20B 57" Rear Projection Television Questions & Answers
0answers
0answers
Changing rk 42 hitachi
yes the 2 watt resistor is actually better than the 1 watt. They will both work in place of each other. The important part are the ohms they have to be exactly the same.
8/8/2012 9:05:21 PM • Hitachi 57UWX20B... • Answered on Aug 08, 2012
Hitachi 57uwx20b convergence question
you have the DP23 chassis IK04 is a STK392-110 and IK05 is the stk392-150 the two resistors RK58 is a 4.7 ohm 1watt metal film resistor and RK62 is a 2.7 ohm 1watt metal film resistor. Only use metal film 1watt 5% resistors
3/8/2012 10:26:26 PM • Hitachi 57UWX20B... • Answered on Mar 08, 2012
I was just given this
First, recheck your cables, and their configuration. Make sure whatever source you're using is properly connected to the television. If possible, check your peripheral devices by hooking them up to another TV.
If you're just connected to cable, and if you've already fiddled with all of the on screen menu settings for audio without any luck, then it's possible the TV has some mechanical defect requiring professional repair, and you should not attempt this yourself.
In the meantime, you can try hooking up a stereo to the TV's audio output jacks (use a pair red and white cables to connect the audio out jack on the TV to the auxiliary jack of a stereo). Turn both of them on, set the stereo to aux, and see if you get sound.
6/9/2011 5:47:23 AM • Hitachi 57UWX20B... • Answered on Jun 09, 2011
Hello Guys is there a replacement screen out there
visit a glass store to help you remove or patch the glass... something like to make glass glossy like on a metal polisher...
2/1/2011 11:54:11 AM • Hitachi 57UWX20B... • Answered on Feb 01, 2011
I have a 57 inch ultravision that has channels
The factory default access code for this TV is 0000.
However, ff you have changed the default code to another number and cannot remember the new number then you can overide this using the combination 7777.
This will overide any changes you made and automatically reset the access code back to 0000. You should now be able to access and change the lock feature using the default 0000.
Hope this helps. Please do leave a vote for the solution. Many thanks.
10/12/2010 7:47:21 PM • Hitachi 57UWX20B... • Answered on Oct 12, 2010
HITACHI 57UWX20B has blue ghost shadows how do I
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
7/3/2010 6:47:35 AM • Hitachi 57UWX20B... • Answered on Jul 03, 2010
How do I change screen size on my hitachi TV with
You can order the correct hand unit for this TV at Mats Electronics 1-800-628-1118
You can also use your CH- Ch+ buttons and the Vol-Vol+ to adjust with after you Press Menu.
7/2/2010 10:28:47 AM • Hitachi 57UWX20B... • Answered on Jul 02, 2010
Hitachi 57UWX20B 57 in.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
5/7/2010 6:38:04 AM • Hitachi 57UWX20B... • Answered on May 07, 2010
My picture is now always a pink to red shade on my
unplug your TV look on the back for a three controls marked red / blue / green "screen" turn / tap on them; watch the screen when you find the "dirty" control clean it with "TV tuner cleaner spray"
3/20/2010 2:06:37 AM • Hitachi 57UWX20B... • Answered on Mar 20, 2010
How do I set up an antenna for tv signal with my
U planning to get free air tv?No need for a converter box,ur tv have digital tuner inside.Just plug in ur antena.Go to ur tv menu go to setup pick air scan all ur channels,well get all free air channels.
2/12/2010 12:52:46 AM • Hitachi 57UWX20B... • Answered on Feb 12, 2010
Hitachi 57uwx20b
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
3/25/2009 3:24:41 AM • Hitachi 57UWX20B... • Answered on Mar 25, 2009
Hitachi 57UWX20B 57" Rear Projection Television Logo
29 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
hitachi 57uwx20b convergence question
  • Televison & Video
