20 Most Recent Hitachi 57S715 57" Rear Projection HDTV Questions & Answers
then I would certainly contact them for replacement,
Hitachi 57S715... | Answered on Oct 14, 2015
This is called image burn, or image retention. There is no cure for this. The image has been burned into your picture tubes from having the same image tuned in for too long.
Hitachi 57S715... | Answered on May 23, 2011
This part is called a protective screen and is part number: KR03265
It can be purchased from encompass.com using the above number for $206.39 plus shipping.
Hope this helps,
Dan
Hitachi 57S715... | Answered on Mar 09, 2011
www.tvrepairworld.com should have the remote for your model.
Hitachi 57S715... | Answered on Mar 04, 2011
It will be cheaper to replace the set.
Sorry.
Hitachi 57S715... | Answered on Feb 28, 2011
your projector gun are not functioning, video circuits, flyback circuits and if this is a dlp type, the xenon bulb is busted..
Hitachi 57S715... | Answered on Feb 09, 2011
no picture and no sound.blue light in front flashes
Hitachi 57S715... | Answered on Jan 22, 2011
Try this one, you can google the model number with the word remote after it also.
http://www.emtcompany.com/hitachi-57s715-remote/rc64.html
SD TECH
Hitachi 57S715... | Answered on Jan 19, 2011
There is a convergence repair kit for the problem you are describing to me. It is for your specific
Hitachi TV.
Here is the link to it.
Hope this helps,
Mark
http://www.tvrepairkits.com/xcart/home.php?cat=1695
Hitachi 57S715... | Answered on Jan 15, 2011
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Hitachi 57S715... | Answered on Jan 13, 2011
rozmyers,
You do not need a high def receiver, your unit has an ATSC tuner which is the same thing. You do need to hook it up to a high definition signal. You mentioned that you have satellite. Call your supplier and order the high definition channels if you do not already have them on the downlink. They should be able to tell you if you have them or not. They should also be able to tell you which channels they are (normally the higher ones). Once you have a high definition feed you will have the best picture you are going to get with todays technology.
Thanks for using FixYa and for the great rating. Please consider a testimonial.
hardrocko
Hitachi 57S715... | Answered on Jan 09, 2011
Unplug the set and remove back cover; follow power cord inside---the fuse should be in a holder and if blown will be blackened inside.
Amperage of fuse will be marked on it and on board next to it; DO NOT BUY REPLACEMENT at Radio Shack, get one from a regular parts dealer, the Generic ones RS sells may blow for no reason.
let me know if you have questions.
SD TECH
Hitachi 57S715... | Answered on Dec 31, 2010
THIS TYPE OF TV REQUIRE 2 SCREENS . SCREEN ASSEMBLY AND SCREEN PROTECTIVE, FIRST ONE PART # KR03143 $276.94 AND THE 2ND PART# KR03265 $ 206.39.
Hitachi 57S715... | Answered on Dec 19, 2010
This happened to me and I was told that it is likely a power supply problem. You ever get a final answer on this?
Hitachi 57S715... | Answered on Aug 23, 2010
My Hitachi 57S715 did the same thing recently. I've been told that it is probably a problem with the power supply. Did you ever get a definitive answer to the problem?
Hitachi 57S715 57" Rear Projection HDTV Logo
38 questions posted
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
need replacement remote
  • Televison & Video
