20 Most Recent Hitachi 46F500 46" Rear Projection HDTV-Ready Television Questions & Answers
Hitachi TV repair
Hello... Rear Projection TVs are not easy to work on. That being said, color issues can be caused by several different things. The most common involves the CRTs (there are three small picture tubes). There is a fluid in each tube that over time can dis-color, and involves a very difficult procedure to fix. Next, there are convergence circuits for each CRT, and one or more can fail. This will not usually cause the symptom you are describing, it will usually cause a double image in some or all areas of the screen and some areas the colors will look fine while other areas will not. It could also be a bad CRT drive board, or the video processing IC. It could even be the high voltage splitter! If I were you, I'd consider a new TV (please get the extended warranty). I hope this helps...
11/26/2017 11:25:55 PM • Hitachi 46F500... • Answered on Nov 26, 2017
To make screen clearer.
Are you using the original remote control...Reg TV doesn't fit your screen because it's not filmed in HD...But it should be clear but you have to watch it smaller... Usually big screen tv's will have a black trim around the picture...And zoom cuts off some of the picture..Some tv's have wide, cinema and other options...Your TV might just have zoom
11/11/2017 9:08:08 AM • Hitachi 46F500... • Answered on Nov 11, 2017
Want to hook pc to tv
Connect HDMI output of laptop to input of tv. If no HDMI output look for laptop video output and get a converter for it to go to the input of tv.
4/1/2016 3:50:48 PM • Hitachi 46F500... • Answered on Apr 01, 2016
My 12 plus year old Hitachi rear projection tv picture is starting to go dark then lightens back up but is getting worse as time goes by ! Whats the problem ?
the problem is,,its 12 years old,its a projection tv,and it hasnt found a home in a dumpster yet
7/23/2015 1:07:46 PM • Hitachi 46F500... • Answered on Jul 23, 2015
How can I hook up a samsung bdf5900 to my hitachi46f500
You will need the following items: B&H # KAHDRGBRL Mfr # HDRGBRL CONVERTER $49.99 B&H # TEAV5RCA06 Mfr # AV-5RCA-06 component cables $9.95 B&H # HOHDMI301 Mfr # HDMI-301.5 HDMI CABLE $9.99 items found at this Web site: http://www.bhphotovideo.com/bnh/controller/home?O=&sku=770115&gclid=CJLlwdGunr4CFW4R7Aod5wMAQA&Q=&is=REG&A=details
5/9/2014 8:20:46 AM • Hitachi 46F500... • Answered on May 09, 2014
0answers
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture. If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
2/8/2013 4:02:25 AM • Hitachi 46F500... • Answered on Feb 08, 2013
Cant switch chan volume or inputs from tv no remote
Go to Wal-Mart, Target, K-Mart, Sears, Best Buy, or any store like that make sure you have your make and model written down with you and go get a universal remote they can run anywhere from $15 to $100. Just make sure the model of remote you buy works with your television set. The instructions are usually pretty easy and involve punching in a code - I recommend once you figure out the code you highlight it in the instructions and write it down on a small piece of paper and use scotch tape to secure it to the inside of the battery cover so you have it when you change the batteries.
1/14/2013 3:11:55 PM • Hitachi 46F500... • Answered on Jan 14, 2013
My red green and blue colors are not aligned
thats a convergence issue you can get the convergence repair kit which contains the parts and instructions from the www.tvrepairworld.com just click on the Hitachi Repair kits catagory then scroll down the page to your models convergence kit.
1/2/2013 10:54:58 AM • Hitachi 46F500... • Answered on Jan 02, 2013
46F500 white smoke
First unplug the unit until problem is found---I would look inside for burnt parts like resistors in the convergence circuit which is the most common issue this set has.They may be discolored or brown in the middle and not actually charred.Locate what burned and you will locate the area where the problem is, many resistors in that area are protection, if a short they destroy themselves very quickly ....If you were having any issue before or at the point it started smoking where picture looked odd or even 3d it will be in the convergence circuit.12_11_2012_4_22_57_pm.jpgNot exact but something like this--the two black chips and resistors in front of them.
12/16/2012 8:27:40 PM • Hitachi 46F500... • Answered on Dec 16, 2012
Blue colors no magic focus stop at blue colors
Check the resistor in front and back of Convergence ICs. STK392-110s. the ICs might need to be replaced also. Look for poor solder connections also.
10/9/2012 1:14:34 AM • Hitachi 46F500... • Answered on Oct 09, 2012
Hitachi 46F500 SCREEN SAYS "LOCKED"
try 1234 or 0000 or call http://www.shopjimmy.com/ and talk to one of the techs on site
9/6/2012 4:48:44 AM • Hitachi 46F500... • Answered on Sep 06, 2012
2answers
Parts
Which board are you refering to as the main circuit board? The power supply PWB ? The Deflection / Convergence PWB ? or the Signal PWB ? respond to this same post and I can help you out, but there isnt a PWB called " main" In that chassis hitachi.
8/15/2012 7:27:01 PM • Hitachi 46F500... • Answered on Aug 15, 2012
Why does my tv have blue and yellow showdes
Please confirm tv model as question shows its Hitachi 46F500 rear projection tv.
How old is this tv?
9/20/2011 7:58:03 PM • Hitachi 46F500... • Answered on Sep 20, 2011
There is red and blue lines around screen and
If model number is as listed (46f500) it does not use a lamp or bulb but has three picture tubes.3d means the two convergence chips in the set have failed.It depends on if you can solder etc, not a very expensive parts cost (under 30 dollars)Can you solder? SD TECH9_17_2011_8_41_12_pm.jpg
9/17/2011 8:41:55 PM • Hitachi 46F500... • Answered on Sep 17, 2011
The picture keeps turning pink
I have a suggestion: when it goes pink go to a black and white channel and examine the screen: if reddish you may be able to adjust the red screen control to correct this.
I can tell you how to do that and please let me know what you find before you rate this information.
SD TECH
8/29/2011 8:48:47 PM • Hitachi 46F500... • Answered on Aug 29, 2011
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
189 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
black white picture red lines vibrating
  • Televison & Video
