20 Most Recent Hitachi C29-F100 29" TV Questions & Answers
Hello i have a hitachi c29-f100 and i would like to restore it with the default settings. Because it's quite old i needed a digital converter but i cant find the video channel where i can see
To do a factory reset, you have to enter its service mode option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
1/30/2015 1:06:57 PM • Hitachi C29-F100... • Answered on Jan 30, 2015
Tell me the remote control model no of hitachi C29-F100
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
8/13/2014 5:52:03 PM • Hitachi C29-F100... • Answered on Aug 13, 2014
Timer light
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.4_19_2012_2_36_48_pm.jpg
4/19/2012 2:36:53 PM • Hitachi C29-F100... • Answered on Apr 19, 2012
It doesn't have a coax connection, what type do I need ?
I had same issue. You need a converter between the cable and the tv. I found one for less than $3.
3/19/2009 7:06:53 PM • Hitachi C29-F100... • Answered on Mar 19, 2009
Menu Language
According to Hitachi themselves, there is no such set with model number C29-F100. The closest one they have on file is the C29-F800. Perhaps your set is an over-seas set, originally sold in Japan? The original remote has a MENU button surrounded by 4 "arrow" buttons - arrow up, down, left and right. For the C29-F800, using the original remote, press the MENU button 4 times or the SETUP button once. There should be 4 choices on that page and the first one, the one on top, is LANGUAGE. Highlight the first one using the "arrow down" (also labeled P-) button and select the language ENGLISH using the left or right arrow buttons. Exit the menu by pressing MENU 3 more times or SETUP once. I believe I can download the owner's manual for the C29-F800 and send it to you if you need it.
3/19/2009 7:03:34 PM • Hitachi C29-F100... • Answered on Mar 19, 2009
Hitachi television repair
Try switching the power off at the PLUG for the night. This will allow the screen to reset. I had a similar problem after a power failure.
1/3/2009 6:23:19 AM • Hitachi C29-F100... • Answered on Jan 03, 2009
Narrow screen
the problem of your tv is in vertical section ,if can locate a trimer( vertical position) try to adjust it and see the effect on screen.
10/19/2008 6:29:10 AM • Hitachi C29-F100... • Answered on Oct 19, 2008
Required sematic digram
vertical amlitute
6/18/2008 6:55:45 PM • Hitachi C29-F100... • Answered on Jun 18, 2008
Hitachi tv shuts off . When I turn on the TV iMessage says please wait then turns off two seconds later.
That sounds like it is not booting properly. I would check for correct power supply opperation and if not that, look for a software reloading procedure in the user instruction manual.
2/11/2024 9:04:18 AM • Hitachi... • Answered on Feb 11, 2024
HI MY NAME IS MAZEN FAHMY I haVE DIODE T3D 36 THIS ZENER & DIODE 2 AND THIS IS IN DATA SHOW HITACHI CP-X3030WN FIX POWER.
https://www.google.com/search?q=DIODE+T3D+36 https://www.google.com/search?q=HITACHI+CP-X3030WN
Original Projector Ballast Main Power Supply For Hitachi ...
AliExpress https://www.aliexpress.com > item Original Projector Ballast Main Power Supply For Hitachi CP-X3030WN. 1/1. 1. US $52.62. Price shown before tax. Free shipping?Free returns. Original Projector ... US$52.62
Projector Power supply For CP-X2530WN CP-X3030WN ...
AliExpress https://m.aliexpress.com > item Projector Lamp Ballast And Power Supply For Hitachi CP-X2530WN. US $80. Projector Lamp Ballast And Power Supply For Hitachi CP-X2530WN. EUC 215g N/T05 ... US$50.00
CP-X2530WN/CP-X3030WN CP-WX3030WN
Projector Central https://www.projectorcentral.com > pdf > projecto... power supply make the projector turn on. Setting up. ?This product is also designed for IT power systems with a phase-to- phase voltage of 220 to 240 V ... 118 pages ....
12/5/2023 2:26:21 AM • Hitachi... • Answered on Dec 05, 2023
Change input on Hitachi LCD TV model LE65K6R9 without remote?
I'd unplug/disconnect the Roku and after 30 seconds try the control button on the back. If you can change the input do so, then plug the Roku back in. Until you use the input button on the back to change input to Roku, you should be able to use the other buttons on the back to control the TV. If this does not work, unplug both the TV and the Roku. Wait maybe a minute, then plug the TV back in and follow the above instructions. Here are other alternatives: Using physical buttons: You can find the physical buttons on the left or right back side of the Hitachi TV. Using these keys, you can change the input, adjust the volume, or turn on Hitachi TV without a remote. Press the Input button located at the back or side of the Hitachi TV. The list of connected sources will appear on the TV screen12. Using external devices: Connect a wireless keyboard or mouse to your Hitachi TV and change the input1. Buy a universal remote: You can buy a universal remote to control your Hitachi TV and change the source.
10/13/2023 9:21:56 PM • Hitachi... • Answered on Oct 13, 2023
How to remove small popup bottom left of Hitachi smart tv screen.
A little popup that appears in the lower left corner of your Hitachi smart TV screen may be related to one of the TV's settings or capabilities. You can attempt the following actions to get rid of it: 1.Investigate notifications: Smart TVs occasionally show notifications for different events or upgrades. If there are any notifications, look for them and then clear them by following the on-screen directions. 2.Applications and Inputs: Make sure all programmes and inputs are closed. The popup may occasionally be connected to an input source or app, which can be closed to get rid of it. 3.On-Screen Display (OSD) Off: There might be an OSD option in the settings menu on Hitachi TVs. Try disabling OSD or changing its settings to see if it gets rid of the popup. Verify any software/firmware updates: 4.Make that the most recent firmware or software upgrades are installed on your TV. Pop-up windows may appear as a result of faults in outdated software. Look for a software update option in the TV's settings menu. 5.Firmware Reset: You can conduct a factory reset on your TV if the problem persists after you've tried various troubleshooting measures. The default values for all settings will be restored as a result. Make cautious to back up any crucial data before doing a factory reset because doing so will also remove any customised settings and data. 6.Message Hitachi Support here: If none of the aforementioned fixes the problem, it's a good idea to get in touch with Hitachi customer service or refer to the TV's user manual for detailed instructions on how to get rid of the popup. Regarding External Devices: 7.The popup may be related to any external devices you have connected to your TV, like a cable box or game console. Make sure that these gadgets are operating properly and that the settings have been changed as necessary. Keep in mind that depending on the type and software version of your Hitachi smart TV, the precise processes and options may change. For instructions unique to your TV model, consult the user manual, or go to the Hitachi website for further help options.
9/30/2023 6:30:41 PM • Hitachi... • Answered on Sep 30, 2023
Hitachi LE42S704 none of the HDMI ports work, need to update (i think)
Are you getting the various HDMI inputs on the screen but it acts like nothing is connected? We have repaired hundreds of TV's with no HDMI signal over the years and have never had an update correct this issue. There is an IC close to the HDMI input jacks (U501) that decodes the data, that's always been the defective part. You can order the part and change it but you will need advanced soldering skills and the equipment to do it, I'd recommend replacing the main board if you can find one.
5/23/2023 4:18:27 AM • Hitachi... • Answered on May 23, 2023
I bought a Hitachi (L22DG07U) 22 Inch LED LCD DVD Combi TV everything else works perfectly except the fact that the DVD doesn't talk but the TV talk well, what do I do?
Take it in for repair unless you are a DVD repair person. The only thing you can try is a DVD Cleaning disc. You don't say what it does or doesn't do except it 'doesn't talk'. Well it isn't supposed to talk, it should play DVDs :>D Only Smart televisions have Bluetooth. Here is your manual, you could attach an external DVD if you can find one that has a SCART connector. https://www.manualslib.com/manual/466636/Hitachi-L22dg07u.html?page=12#manual It is 11 years old according to the review, and it get 6/10. https://www.avforums.com/reviews/hitachi-l22dg07u-22-inch-led-lcd-dvd-combi-tv-review.360/#:~:text=The%20energy%20efficiency%20is%20excellent,music%20via%20the%20USB%20port. ..
4/26/2023 10:08:44 PM • Hitachi... • Answered on Apr 26, 2023
2answers
Can't highlight or select digital channels to autoscan on hitachi 51f59a
It sounds like you're experiencing an issue with your Hitachi 51F59A TV not allowing you to select or highlight digital channels for autoscan. Here are a few things you can try to resolve the issue:
  1. Check the TV's settings: Make sure the TV is set to the correct input (such as "TV" or "antenna") and that the channel search or autoscan feature is turned on. Consult the TV's manual or the on-screen menu for instructions on how to access these settings.
  2. Check the TV's connection: Make sure the TV is properly connected to a digital antenna or cable box. Also, check that the cables are securely connected and not damaged.
  3. Check for a firmware update: Sometimes a firmware update can resolve issues like this. Check the TV's manual or the manufacturer's website for instructions on how to check for and install firmware updates.
  4. Try a factory reset: If the above steps don't work, you can try performing a factory reset on the TV. This will restore the TV to its original settings and may resolve any issues with the channel search or autoscan feature. Consult the TV's manual or the on-screen menu for instructions on how to perform a factory reset.
  5. Check for a hardware issue: If none of the above solutions work, the issue could be caused by a hardware problem with the TV. In this case, you may need to contact the manufacturer or a repair professional to have the TV serviced.
3/18/2023 8:43:58 AM • Hitachi... • Answered on Mar 18, 2023
Hitachi 65r8 no backlighting
It's the strips themselves that are bad
2/27/2023 7:32:45 PM • Hitachi... • Answered on Feb 27, 2023
Hitachi L40A105 closed caption
Do you have the captions set for Analog or Digital captions? The advanced setting is only available for digital captions. See https://www.manualslib.com/manual/520286/Hitachi-Alpha-L40a105.html?page=19#manual . I hope this helps. Cindy Wells
1/26/2023 11:49:34 PM • Hitachi... • Answered on Jan 26, 2023
HITACHI AX-M71 MUSIC SYSTEM REMOTE
1/23/2023 11:33:19 PM • Hitachi... • Answered on Jan 23, 2023
Hitachi C29-F100 29" TV Logo
Popular Tags
16 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
hitachi c29 f100 like restore default
  • Televison & Video
