20 Most Recent
Diesel Engine Control Unit Re526588 Questions & Answers
My man diesel TGA 18.350. it shows me on the dashboard coads 01080_5 and 03076_9 and 03792_5 please i sent my questions but i did not get an answer please i need help
difficulty in find a web page that has the codes properly explained
one site I found ---techtransa.It has a list or the numbers before the under score and what the fault areas are
To get there I went google and typed in--mandiesel model tga-18-350 fault codes--
there are other pages that make reference to fault codes but are not specific to your model
reading around the fault codes are specific to man and it seems that a normal obd-11 scanner will not be accurate
you might have time to down load a good site when you find one , but as I consider a heavy vehicle should be out earning income , time off the road costs money so, in the mean time and until you can find a down load for the faults, maybe you should take it to a service dealer and have it fixed
possible even to get a copy of the codes from the technician
7/20/2016 7:45:56 AM •
Diesel Toys
Answered
on Jul 20, 2016
What would be causing my MF65 to blow diesel out of the dipstick?
If your machine is truly spraying fuel oil out of the dipstick tube, you most likely have some severe engine damage, most likely originating from a leaky (dripping) fuel injector/nozzle. The fact that fuel oil is present in the crankcase leads me to believe that at least one cylinder has been overfueling, causing wash-down of the cylinder walls and resultant piston ring and cylinder wall (or liner) damage. Enough raw fuel is getting (first) into the cylinder and (second) into the crankcase to wash the normal oil film off the cylinder walls, resulting in excessive ring and cylinder wear. In all likelihood, you now have excessive crankcase pressure due to the damaged rings and cylinder walls, as compression pressure is being lost into the crankcase..
Have this engine evaluated by a professional, as a tear-down and rebuild is very likely necessary. At the very least, the fuel system -- injectors/nozzles specifically -- must be investigated and repaired...
5/5/2016 2:06:28 PM •
Diesel Toys
Answered
on May 05, 2016
How do I remove the broken end of the tach drive recessed into the end of the camshaft on my massey ferguson 65 diesel
Hi Bill:
Here's a trick you might try. It should work if the broken part is not physically attached and if it is magnetic.
Find a short piece of plastic tube, even a drinking straw will do, that will slide into the hole.
Find a common nail that will just slide into the tube. Grind the pointed end off the nail so it is flat.
Slide the plastic tube over the nail also that it bumps into the head, then cut the tube off flush with the flat end.
Slide the tube with the nail in it into the hole in the end of the crankshaft.
Take your handy super magnet and touch it to the head of the nail.
If you are lucky, if you gently pull the nail/tube out with the magnet attached, the broken but will come out.
Hope this helps.
2/6/2016 12:27:19 AM •
Diesel Toys
Answered
on Feb 06, 2016
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part:
1. Contact the Manufacturer:
- Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod.
- Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component.
2. Check for Spare Parts:
- Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components.
- Look for any contact information provided for customer support or spare parts inquiries.
3. Online Search:
- Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase.
- Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture.
4. Local Retailers:
- Visit local baby product stores or furniture stores that carry nursery items.
- Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component.
5. Custom Fabrication:
- If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib.
- Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM •
Toys
Answered
on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
- Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
- Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
- Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
- Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
- Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM •
Toys
Answered
on Mar 21, 2024
