20 Most Recent BenQ PB6100 Multimedia Projector Questions & Answers
4answers
Projector shuts down after only a few minutes.
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at [email protected]
1/27/2022 10:39:06 AM • BenQ PB6100... • Answered on Jan 27, 2022
I have a PB6200 BenQ
There's a display "toggle" sequence on your computer to send the signal to your external post (VGA?). Look at the Function keys (top row) for a screen icon. Hold Fn key down and press that Function key (on Dell, usually F8). You should get an indication on your screen of which outputs are active -- look for BOTH.
5/28/2017 1:43:07 PM • BenQ PB6100... • Answered on May 28, 2017
0answers
0answers
0answers
0answers
2answers
If I turn on the
I had the exact same problem, I followed the advice of Victorbello on this site, and found a bulging capacitor where he suggested to look. Read where below.
I soldered in a new one from Radio Shack ($1.50) and the projector works again.
PB6200 symptoms: Back fans were not working Bulb won't light (but is in perfect condition) LEDs on control light, but not three status LEDs Internal fan will not turn off.
Solution: The mainboard had a bad capacitor The board is the one where all 3 fans are connected, and which is facing upside down on top of the powerboard.
The bad capacitor on my projector was a 25V 470uf 10mm diameter, 16mm high, 5mm lead spacing capacitor.
"I recommend you to open your projector, unplug all connections to the fan board, turn it upside, and inspect the capacitors and other components. Bad capacitors have a bulge and/or a black stain or fluid coming out on the top."
3/11/2014 1:08:05 PM • BenQ PB6100... • Answered on Mar 11, 2014
0answers
Factory reset
Be the first to answer 1/14/2014 4:38:10 AM • BenQ PB6100... • Posted on Jan 14, 2014Be the first to answer
2answers
Can't access Menu
I have the same problem, any ideas to solve.Thankyou
12/14/2013 11:09:32 AM • BenQ PB6100... • Answered on Dec 14, 2013
5answers
Benq pb6100, light bulb does not on, power ok
I fixed the exact same problem on my PB6200. Both back fans were not working, and the bulb would not turn on.
In my projector, the fan board had a bad capacitor. The fan board is the one where all 3 fans are connected, and which is facing upside down on top of the powerboard. The bad capacitor on my projector was coded C7302 on the schematics. It's a brown, 25v 470uf capacitor.
I recommend you to open your projector, unplug all connections to the fan board, turn it upside, and inspect the capacitors and other components. Bad capacitors have a bulge and/or a black stain or fluid coming out on the top. You can find pictures on the net.
6/4/2013 2:39:51 AM • BenQ PB6100... • Answered on Jun 04, 2013
3answers
My BenQ PB6200 Projector image
Hello
Get into 'Menu' => 'Source Menu'
In Fucttion you can see descriptions. If the projector is at table postion, the image will he correct as it is the default set by cmpany. If the projector is ceiling mounted, select "Ceiling mount". When you select celing mount option when the projector is placed on table, the image will be inverted. Your selection should be saved in the projectors' memory IC as you switch off the device. When you switch ON it again, the same settings should be retrieved from its memory IC, and last position memory status should be thee. If not, be sure that the memory IC in the circuit baord is defective,a nd should be replaced with same type and number. This is a very skilled service work, and should be done by amy well experienced service technician; or by the Authorised Service Center for BenQ at your town. Replacing mamory IC is not a job easly done by the customer. OK.
9/11/2011 11:58:48 AM • BenQ PB6100... • Answered on Sep 11, 2011
My ben q mp512 projector
This happens during the bulb initialize phase. Your bulb is bad and will need replaced.
9/2/2011 7:00:39 AM • BenQ PB6100... • Answered on Sep 02, 2011
BenQ PB6100 Multimedia Projector Logo
131 questions posted
Top BenQ Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • BenQ Office Equipment & Supplies
Most Popular Question
turn
  • Office Equipment & Supplies
