20 Most Recent Hitachi VT-RM380A Remote Control Questions & Answers
2answers
Intructions for programming a remote control
I own this remote. Here are the instructions.
1 turn on your tv or catv
2 aim remote at tv or catv
3 while holding tv or catv button press 0 to 9 last ch 100/ent or channel
4 release both buutons when tv or catv changes channel.
note press tv or vcr or catv button first to select desired function
3/19/2014 10:04:55 PM • Hitachi... • Answered on Mar 19, 2014
Hitachi tv shuts off . When I turn on the TV iMessage says please wait then turns off two seconds later.
That sounds like it is not booting properly. I would check for correct power supply opperation and if not that, look for a software reloading procedure in the user instruction manual.
2/11/2024 9:04:18 AM • Hitachi... • Answered on Feb 11, 2024
HI MY NAME IS MAZEN FAHMY I haVE DIODE T3D 36 THIS ZENER & DIODE 2 AND THIS IS IN DATA SHOW HITACHI CP-X3030WN FIX POWER.
https://www.google.com/search?q=DIODE+T3D+36 https://www.google.com/search?q=HITACHI+CP-X3030WN
Original Projector Ballast Main Power Supply For Hitachi ...
AliExpress https://www.aliexpress.com > item Original Projector Ballast Main Power Supply For Hitachi CP-X3030WN. 1/1. 1. US $52.62. Price shown before tax. Free shipping?Free returns. Original Projector ... US$52.62
Projector Power supply For CP-X2530WN CP-X3030WN ...
AliExpress https://m.aliexpress.com > item Projector Lamp Ballast And Power Supply For Hitachi CP-X2530WN. US $80. Projector Lamp Ballast And Power Supply For Hitachi CP-X2530WN. EUC 215g N/T05 ... US$50.00
CP-X2530WN/CP-X3030WN CP-WX3030WN
Projector Central https://www.projectorcentral.com > pdf > projecto... power supply make the projector turn on. Setting up. ?This product is also designed for IT power systems with a phase-to- phase voltage of 220 to 240 V ... 118 pages ....
12/5/2023 2:26:21 AM • Hitachi... • Answered on Dec 05, 2023
Change input on Hitachi LCD TV model LE65K6R9 without remote?
I'd unplug/disconnect the Roku and after 30 seconds try the control button on the back. If you can change the input do so, then plug the Roku back in. Until you use the input button on the back to change input to Roku, you should be able to use the other buttons on the back to control the TV. If this does not work, unplug both the TV and the Roku. Wait maybe a minute, then plug the TV back in and follow the above instructions. Here are other alternatives: Using physical buttons: You can find the physical buttons on the left or right back side of the Hitachi TV. Using these keys, you can change the input, adjust the volume, or turn on Hitachi TV without a remote. Press the Input button located at the back or side of the Hitachi TV. The list of connected sources will appear on the TV screen12. Using external devices: Connect a wireless keyboard or mouse to your Hitachi TV and change the input1. Buy a universal remote: You can buy a universal remote to control your Hitachi TV and change the source.
10/13/2023 9:21:56 PM • Hitachi... • Answered on Oct 13, 2023
How to remove small popup bottom left of Hitachi smart tv screen.
A little popup that appears in the lower left corner of your Hitachi smart TV screen may be related to one of the TV's settings or capabilities. You can attempt the following actions to get rid of it: 1.Investigate notifications: Smart TVs occasionally show notifications for different events or upgrades. If there are any notifications, look for them and then clear them by following the on-screen directions. 2.Applications and Inputs: Make sure all programmes and inputs are closed. The popup may occasionally be connected to an input source or app, which can be closed to get rid of it. 3.On-Screen Display (OSD) Off: There might be an OSD option in the settings menu on Hitachi TVs. Try disabling OSD or changing its settings to see if it gets rid of the popup. Verify any software/firmware updates: 4.Make that the most recent firmware or software upgrades are installed on your TV. Pop-up windows may appear as a result of faults in outdated software. Look for a software update option in the TV's settings menu. 5.Firmware Reset: You can conduct a factory reset on your TV if the problem persists after you've tried various troubleshooting measures. The default values for all settings will be restored as a result. Make cautious to back up any crucial data before doing a factory reset because doing so will also remove any customised settings and data. 6.Message Hitachi Support here: If none of the aforementioned fixes the problem, it's a good idea to get in touch with Hitachi customer service or refer to the TV's user manual for detailed instructions on how to get rid of the popup. Regarding External Devices: 7.The popup may be related to any external devices you have connected to your TV, like a cable box or game console. Make sure that these gadgets are operating properly and that the settings have been changed as necessary. Keep in mind that depending on the type and software version of your Hitachi smart TV, the precise processes and options may change. For instructions unique to your TV model, consult the user manual, or go to the Hitachi website for further help options.
9/30/2023 6:30:41 PM • Hitachi... • Answered on Sep 30, 2023
Hitachi LE42S704 none of the HDMI ports work, need to update (i think)
Are you getting the various HDMI inputs on the screen but it acts like nothing is connected? We have repaired hundreds of TV's with no HDMI signal over the years and have never had an update correct this issue. There is an IC close to the HDMI input jacks (U501) that decodes the data, that's always been the defective part. You can order the part and change it but you will need advanced soldering skills and the equipment to do it, I'd recommend replacing the main board if you can find one.
5/23/2023 4:18:27 AM • Hitachi... • Answered on May 23, 2023
I bought a Hitachi (L22DG07U) 22 Inch LED LCD DVD Combi TV everything else works perfectly except the fact that the DVD doesn't talk but the TV talk well, what do I do?
Take it in for repair unless you are a DVD repair person. The only thing you can try is a DVD Cleaning disc. You don't say what it does or doesn't do except it 'doesn't talk'. Well it isn't supposed to talk, it should play DVDs :>D Only Smart televisions have Bluetooth. Here is your manual, you could attach an external DVD if you can find one that has a SCART connector. https://www.manualslib.com/manual/466636/Hitachi-L22dg07u.html?page=12#manual It is 11 years old according to the review, and it get 6/10. https://www.avforums.com/reviews/hitachi-l22dg07u-22-inch-led-lcd-dvd-combi-tv-review.360/#:~:text=The%20energy%20efficiency%20is%20excellent,music%20via%20the%20USB%20port. ..
4/26/2023 10:08:44 PM • Hitachi... • Answered on Apr 26, 2023
2answers
Can't highlight or select digital channels to autoscan on hitachi 51f59a
It sounds like you're experiencing an issue with your Hitachi 51F59A TV not allowing you to select or highlight digital channels for autoscan. Here are a few things you can try to resolve the issue:
  1. Check the TV's settings: Make sure the TV is set to the correct input (such as "TV" or "antenna") and that the channel search or autoscan feature is turned on. Consult the TV's manual or the on-screen menu for instructions on how to access these settings.
  2. Check the TV's connection: Make sure the TV is properly connected to a digital antenna or cable box. Also, check that the cables are securely connected and not damaged.
  3. Check for a firmware update: Sometimes a firmware update can resolve issues like this. Check the TV's manual or the manufacturer's website for instructions on how to check for and install firmware updates.
  4. Try a factory reset: If the above steps don't work, you can try performing a factory reset on the TV. This will restore the TV to its original settings and may resolve any issues with the channel search or autoscan feature. Consult the TV's manual or the on-screen menu for instructions on how to perform a factory reset.
  5. Check for a hardware issue: If none of the above solutions work, the issue could be caused by a hardware problem with the TV. In this case, you may need to contact the manufacturer or a repair professional to have the TV serviced.
3/18/2023 8:43:58 AM • Hitachi... • Answered on Mar 18, 2023
Hitachi 65r8 no backlighting
It's the strips themselves that are bad
2/27/2023 7:32:45 PM • Hitachi... • Answered on Feb 27, 2023
Hitachi L40A105 closed caption
Do you have the captions set for Analog or Digital captions? The advanced setting is only available for digital captions. See https://www.manualslib.com/manual/520286/Hitachi-Alpha-L40a105.html?page=19#manual . I hope this helps. Cindy Wells
1/26/2023 11:49:34 PM • Hitachi... • Answered on Jan 26, 2023
HITACHI AX-M71 MUSIC SYSTEM REMOTE
1/23/2023 11:33:19 PM • Hitachi... • Answered on Jan 23, 2023
8.5tr ductable hitachi in remote red light blinking continues what the reason
count the blinks and refer it from user manual trouble shoot section , you will find the reason
1/19/2023 7:29:04 PM • Hitachi... • Answered on Jan 19, 2023
Hitachi tv black screen ?
but nothing else If your Hitachi television has sound but a black screen, it is likely that either the bulb or the inverter has gone bad. The inverter is a part of the backlight system. If the inverter is not functioning, the backlight will not work and the television will be dark. You should check to see if the bulb needs to be replaced first. If the bulb is working and the inverter doesn't turn on, then you may need to have a technician take a look at the television.
1/6/2023 3:08:36 PM • Hitachi... • Answered on Jan 06, 2023
2answers
I have a Hitachi lcd model 50A3. Won't come on and has the blue light instead of red
Hello, more than likely the set has bad back lights, a very common issue with these sets...sorry. Techman 57
11/5/2022 4:35:45 AM • Hitachi... • Answered on Nov 05, 2022
2answers
How do I get the language settings back to English on My Hitachi TV Please ?
https://www.askmefast.com/How_do_i_change_the_language_to_english_on_my_hitachi_50hxt16u_please-qna7526359.html#q4753135
11/5/2022 4:28:04 AM • Hitachi... • Answered on Nov 05, 2022
My Hitachi 65F59A has a blue tint picture all the time? How do I Resolve this? Thank you
Hi, you would need to use your display settings to change the tint. There might be a tint or a hue option that you can press with the display settings. Thank you.
10/7/2022 6:57:00 PM • Hitachi... • Answered on Oct 07, 2022
Toshiba 55HT1U flash of blue when powering up - no other sign of life
An 11 year set isn't worth repairing, time for a new TV
9/13/2022 11:33:41 PM • Hitachi... • Answered on Sep 13, 2022
HITACHI 55HK6100U SMART TV REMOTE CONTROL CAUSES INTERFERENCE ON PICTURE
There is a post about this issue on the AVI blog. There are several people that have had the issue. No one claims a fix for it though. Seems to be related to HDMI cables and how close they are to the remote extender runs.
8/23/2022 2:15:45 AM • Hitachi... • Answered on Aug 23, 2022
I need an manual for my hitachi WD9000
going to have to navigate with the buttons go into source and change from tv to hdmi you want
8/7/2022 6:06:12 AM • Hitachi... • Answered on Aug 07, 2022
Televison & Video Logo
5 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
intructions programming remote control
  • Televison & Video
