20 Most Recent
Canon LaserClass 2050 Plain Paper Fax Questions & Answers
SAYS PAPER JAM BUT THERE IS NO PAPER JAMMED?
Open it up to see if there is debris in the unit, Could drop a pencil, small piece of paper, paper clip, etc. in unit. Turn it over to see it something falls out. Clean it as best you can.
Check cover/cart appears. tried changing
the message you are getting will show up for both toner and cover. There is a switch that the cover triggers when closed located onder the main unit cover. The tab on the cover goes into a slot located kinda left of center. That switch is infamous for getting stuck or knocked out of place so the tab does not see it. The cartridge is probably good.
Cant get incoming fax
be sure phone cord is plugged into line port..not tel. Or your machine is in manual mode. Press button under lcd panel that says recieve mode until display reads fax/tel.
Machine is saying "output tray full" no faxes
Open the fax. There is a small door that allows access to the fuser for jams. There is a little black tab to the right on the door. Reseat it so it is level and pivots freely. Close up machine should start faxing. This tab is a flag for a photointerupter. Is easily knocked out nof place.
How to feed paper through
Section 2-39 thru 2-45 of the user manual will give you a step by step photo presentation of how to load the paper. If you do not have the manual, please send me an email to
[email protected] and I will send it to you. Please put "canon LC2050" as the subject.
324 ERROR ON CANNON 2050P
That is a laser scanner code. Sometimes the power supply will also throw this error. The power supply is located under the long plastic cover in the back and is easily replaced. The cost for a laser unit is quite pricey and not really worth it. A new fax can be purchased for about the same coin.
Cheak cover
When you open cover, from left inner side of cover is plastic nose, that fits into sensor hole. With screwdriver, remove 4 screws, remove fax cover, and put sensor in upper position.
How do i change the name on my fax machine?
on the right side theres a flap that can lift up!(the one with your speed dails!)Press data registration and then set/ok,it will say user settings and press set/ok again!It says ate and time,use the arrows down and go to user name, press set/ok and type in your name,press set/ok and stop!Enjoy!!
I have a Cannon PC940
the problem is not from the contrast but the toner inside ..probably it is the developer and the roller that needs to be cleaned...cause something was wrong with the cartridges last time when you changed them ..cause it is not supposed to lick like that ...anyway ..open it up ..and clean it good..also the developer and all it is ..after that I suggest to change the cartridge cause it is either licking or it is not good from the factory ...and it will print...it may print a few lines after that ..for a while until it cleans itself for good..but it is definitely not a setting or contrast issue..
How do you access bypass tray?
The bypass tray is refered to as the multi-purpose (MP) tray. It is located vertically on top at the back of the fax machine. The fax needs to be programmed (told what size of paper is loaded) by opening the One-Touch Speed Dialing panel, press the 'Data Registration' button, press 'Set' button, then using up or down arrows to select " 5.PRINTER SETTINGS ". Press 'Set' button, then press down arrow to display " 2.PAPER SIZE ". Press 'Set', use arrow s to select CASSETTE or MP TRAY. Use arrows to select appropriate size of paper loaded. Press 'Set'. Press 'Stop' button to return to standby mode. Reference pages 15-11 and 15-12 in LC 2050 Users Guide.
How to change the time?
Open the One-Touch Speed Dialing panel. Press 'Data Registration' button. Press 'Set' button twice. Press 'Set' button again, then use the numeric buttons to enter the correct month, day, year, and time in this order. Press 'Set' button to save the date and time. Press 'Stop' button to return to standby mode. (reference page 3-9 in the Users Manual)
