20 Most Recent
Canon NP 6650II Copier Questions & Answers
Error code E001; machines switches
Your in luck, Canon really did not change there error codes from way back then..... A E001 means you have a problem with the fusing unit. You may have a blown thermal fuse or one of the heatting lamps or you may have a bad thermister. It may be one or all of them. Did you try to rest the error code?
Mesin saya canon np 6650
PAGI gan saya mau tanya foto copy saya NP6650 II di monitor ada tulisan nya 002 ! TURN THE POWER ON AGAIN BAGAIMANA SOLUSINYA TRIMA KASIH
I have canon np 6650
if error E010 occure, it means your Main motor not running,
motor or motor drive board or mother board problem,
if show E010 after running the main motor, check motor driver board or mother board,
but 99.9% case of E010, cause of main motor problem so check the main motor first,
What means of po cont
PO cont means Drum Potential Control,
If po cont set to 0, it means scanner system adjust the document darkness automatically but you may face many printing problems such like auomaically over dark, over light, heizzy, dull, etc etc.
if you want to trouble free printing, please set PO-Cont to 1
