20 Most Recent Hitachi CMPAS04 TV Speakers Questions & Answers
I have a pair of Hitachi speakers probably off of
you need a amplifier
because most computer speakers have amplifiers in them and they plug into the wall
the speakers that you are plugging into the computer have a impedance which is too high for the computer but the impedance is normal for a stereo or tv
so i recomend you get a cheap amplifier
or a cheap set of computer speakers with amplifier take out the speakers and attach the hitachi speakers in place of the orginal
and it should work
5/10/2010 8:13:38 AM • Hitachi CMPAS04... • Answered on May 10, 2010
How do I set the time on Hitachi RAR-3U1 so that I cn get the remote to operate.
Hi, had the same problem and finally worked it out.
Make sure the mode button works by changing between auto,heat,cool,dehumod and fan.
Put it on anything but auto
Hit the middle clock button so that it keeps flashing
Then simply hit the up down and the time will change
Once set hit the clock button and it will save
1/27/2024 2:02:11 AM • Hitachi Audio... • Answered on Jan 27, 2024
HItachi ax-m77 manual
hitachi's site or online search
4/8/2020 6:05:21 PM • Hitachi Audio... • Answered on Apr 08, 2020
Hitachi stereo amplifier ha-6 A and B speaker output not turning on
Hello Ricardo, for what you comment, you would have a fault in the exit stage of your Hitachi Test, with the equipment turned on, operate the keys of System A or System B and in doing so, you should hear, inside the amplifier, the noise produced by the relay speakers, if you do not hear it, it would indicate the fault in the exit stage There may be a channel or both channels wrong I suggest you look for a specialized technical service Greetings Franco Dosil Hola Ricardo, por lo que comentas, tendrias una falla en la etapa de salida de tu Hitachi Prueba, con el equipo encendido, accionar las llaves de Sistema A o Sistema B y al hacerlo, deberias escuchar, en el interior del amplificador, el ruido que producen los rele de conexion de parlantes, si no lo escuchas, indicaria la falla en la etapa de salida Puede estar un canal o los dos canales mal Te sugiero buscar un servicio tecnico especializado Saludos Franco Dosil https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Hitachi-HA-6-Service-Manual.pdf https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Hitachi-HA-6-Schematic.pdf https://www.radiomuseum.org/r/hitachi_ha_6.html
6/18/2019 3:33:36 AM • Hitachi Audio... • Answered on Jun 18, 2019
Hitachi axm649u manual wanted to let me tune dab
Hello Andi, I sent you the link so you can download the user manual I hope that you can solve your concern Greetings Franco Dosil Hola Andi, te envio el link para que puedas descargar el manual de usuario Espero Que puedas resolver tu inquietud Saludos Franco Dosil https://data2.manualslib.com/pdf5/112/11111/1111069-hitachi/axm649bt.pdf?778bbd45e1ee17ba493e1c672ab8ba37&take=binary
5/20/2019 6:47:14 PM • Hitachi Audio... • Answered on May 20, 2019
Why is my question not being answered as requested, how to preset radio stations on Hitachi AXM649U?
Download the service manual and read it. Regards, Serge.
2/12/2019 11:57:00 PM • Hitachi Audio... • Answered on Feb 12, 2019
Looking for antenna for hitachi ax.m130
Just go to the shop
9/17/2017 8:29:30 AM • Hitachi Audio... • Answered on Sep 17, 2017
0answers
Be the first to answer 6/21/2017 9:48:03 AM • Hitachi Audio... • Posted on Jun 21, 2017Be the first to answer
Hitachi d-e65 cassette deck replaced the belts & now makes noise when played & the ffw/rew stopped working
Clearly they have not been put back in the right place!
3/8/2017 4:50:00 PM • Hitachi Audio... • Answered on Mar 08, 2017
Hitachi CMPAS04 TV Speakers Logo
1 questions posted
Top Hitachi Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Hitachi Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Audio Players & Recorders
Most Popular Question
pair hitachi speakers probably off
  • Audio Players & Recorders
