20 Most Recent
Epson Stylus NX515 Questions & Answers
How to replace ink cartridge for Epson stylus nx515?
Caution:
Leave your old cartridges in the printer until you are ready to replace them to prevent the print head nozzles from drying out. Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1)Turn on your product.
2)Lift up the scanner unit.
Caution:
Do not move the print head by hand; otherwise, you may damage your product. Do not touch the flat white cable inside the printer.
Press the stop button.
If a cartridge is low or expended, the print head moves that cartridge to the indicator position. Press the stop button again to check for additional low or expended cartridges. When all cartridges have been identified, the print head moves to the replacement position.
If no cartridges are low or expended, the print head does not move. If you want to replace a cartridge before it is low or expended, press the stop button for 6 seconds. The print head moves to the replacement position.
Squeeze the tab on the cartridge and lift the cartridge straight up to remove it.
Note: Dispose of used cartridges carefully. Do not take the used cartridge apart or try to refill it.
Warning: If ink gets on your skin, wash it thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. If ink gets into your mouth, spit it out and see a doctor right away. Keep ink cartridges out of the reach of children.
Before opening the new cartridge package, shake it gently four or five times.
Caution:
Do not shake the cartridges after opening the packages, or ink may leak.
Remove the cartridge from the package.
Caution:
Do not touch the green chip or the small window on the cartridge. Install the new cartridge immediately after removing the old one; if you do not, the print head may dry out and be unable to print.
Remove the yellow tape from the side of the cartridge.
Caution:
Do not remove any other labels or seals, or ink will leak.
Insert the new cartridge into the holder and push it down until it clicks into place.
Press the stop button. The print head moves to its home position and the printer starts charging the ink. This takes about 1.5 minutes. When the power light stops flashing and remains on, ink charging is finished.
Caution:
Never turn off the product while the power light is flashing or you will waste ink. Thanks
Epson Projector S05 text is shodow
If the text on your Epson EB-S05 projector is appearing blurry or shadowed, there are several possible causes and solutions to consider:
- Check the focus: Make sure the projector is in focus by adjusting the focus ring. If the text still appears blurry, try adjusting the position of the projector or the screen.
- Check the resolution: If the input resolution of your projector does not match the native resolution of your display or screen, the text may appear blurry or shadowed. Check the resolution settings on both your projector and your device to make sure they match.
- Check the cables: If the cables connecting your projector to your device are old or damaged, they may cause interference or display issues. Try replacing the cables with new ones and see if that improves the text clarity.
- Check the lamp: If the lamp on your projector is old or damaged, it may cause the image to appear dim or blurry. Check the lamp hours and replace the lamp if necessary.
- Check the settings: Make sure that the brightness, contrast, and other settings on your projector are properly adjusted. Experiment with different settings to find the optimal image quality.
If none of these solutions work, it may be necessary to consult the Epson customer support or to take the projector to a professional technician for repair.
Epson Artisan 835 waste pad cleaning or replacement, how?
The Epson Artisan 835 waste pad is located in the printer's waste ink compartment and is designed to absorb any excess ink that is generated during the printing process. Over time, the waste pad can become saturated with ink, which can cause issues with the printer's performance.
To clean or replace the waste pad on an Epson Artisan 835 printer, you will need to follow these steps:
- Turn off the printer and unplug it from the power source.
- Open the printer's cover and locate the waste ink compartment.
- Carefully remove the waste pad from the compartment.
- Clean the waste pad with a damp cloth, or replace it with a new one if it is heavily saturated with ink.
- Reinstall the waste pad into the waste ink compartment.
- Close the printer cover and plug the printer back in.
It's important to note that this process can be messy and you should use gloves and old clothes to avoid getting ink on your hands or clothes. Also, some printer models may have a different process to access the waste pad, you might need to consult the printer's manual or Epson website to know more about your specific model.
Is there anyway to connect my Chromebook to my Epson EMP-83H projector when my Chromebook only has either a USB or 2 Type -C ports?
Yes, there are a few ways to connect your Chromebook to an Epson EMP-83H projector even if your Chromebook only has a USB or 2 Type-C ports. Here are a few options you can try:
- Use a USB-C to HDMI adapter: If your projector has an HDMI input, you can use a USB-C to HDMI adapter to connect the projector to one of your Chromebook's Type-C ports. This will allow you to mirror your Chromebook's screen on the projector.
- Use a USB-C to VGA adapter: If your projector has a VGA input, you can use a USB-C to VGA adapter to connect the projector to one of your Chromebook's Type-C ports. This will allow you to mirror your Chromebook's screen on the projector.
- Use a Chromecast or similar device: You can use a Chromecast or similar device that can be connected to the projector via HDMI, this device will let you mirror your Chromebook's screen on the projector wirelessly.
- Use Google Meet: If the projector have internet connectivity, you can use Google Meet on your Chromebook to conduct a video call, you can share the screen of your Chromebook with the projector and use it as if it were connected through cable.
- Use a USB-C to USB adapter: If your projector has a USB input, you can use a USB-C to USB adapter to connect the projector to one of your Chromebook's Type-C ports. This will allow you to use the USB function on the projector, such as using a USB drive to display content on the projector.
It's worth to mention that, Before buying any adapter or device, make sure it's compatible with your projector, and also check the resolution and refresh rate supported by the adapter to ensure that it can meet your needs. Additionally, it's always best to check the instruction manual of your projector and the adapter to ensure that you are using it correctly.
Where can we download Epos Tep 220mc thermal
Hi you can use the Epson TM-88 Driver,
the following link will take you to the Epson download library just check which is the right driver for your operating system and hopefully it will work (there are different types if you are not sure which one is best trial and error is a good option in this case :) ), the manufactures
brochure has more details about this printer it is worth keeping and reading if you own the printer good luck.
Multi media audio controller out of date. No audio
ust
download this software,no need search engine,no more tired of looking
anywhere...instantly,it will be in your laptop for several
minutes....
CLICK ME
KEY : JCCQ-MAKC-KACK-6TSE-BN35
Driver Robot updates:
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
just install it,scan and download... enjoy...
Epson Printer Technical Support pHoNe ~#{+1-855+SCAMMER 67] Number USA
Warning to FixYa readers - DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
Epson Printer Customer Service pHoNe ~@{+1-855@SPAM 67} Number USA
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
EPSON PRINTER TECH SuPpoRt pHoNe nUmBeR #@ {18OO*DELETED 69} RITA USA
EPSON PRINTER TECH SuPpoRt pHoNe nUmBeR #@ {18OODeleted 69} RITA USA
