20 Most Recent
Canon CLC 1150 Color Copier Questions & Answers
CLC 1180 gives the error code E804 000B
E804 0006 The laser scanner motor
cooling fan (FM4) has
stopped to rotate in error.
There is no 000B in the manual....so I assumed it was a six.
The sub codes possible are 0001, 0002, 0003, 0004, 0005, 0006, 0007 and 0008. They all pertain to cooling fan failures.
Canon 1150 E020 04E0 Code error
change all 4 developers plus blow clean both developer sensors you can find these sensors next to the black developer assy it has one screw
E020 0163
E020 is displaying when toner concentration in developer is out of specification and 0163, first two digit 01 means yellow color. it is possible:- that the toner concentration sensor dirty and cannot read the correct value,- there is no yellow toner or the toner not supplied to the developer,- yellow developer is due to replacement.In case you need a service manual for this model it is available at:
http://fixmfp.com/index.php?route=product/product&manufacturer_id=13&product_id=121&page=2
ERROR CODE
there is a problem with the fuser, replace thermistor or thermofuse
