20 Most Recent
Canon PC-1060 Black and White Copier Questions & Answers
Where is the power button
there is no power button on that model, just an energy saver button, machine should power on just by plug in the AC cable
Error E100
The most common cause for E100 is the drum unit. At the rear of the
drum unit should be a small peg pointing into the machine. This gets
broken off. It's purpose is to opperate a laser cut off shield when the
drum is removed so to prevent laser exposure. If peg is missing laser
will not be detected by the system and give E100. Can be repaired or
will require a new drum if it has done more than 40 to 60K copies.
My Canon PC 1060 makes
You a get a technichian to look at your machine simply becouse you might not know where the problem is even if I instruct you, however note this:-
The problem is with the fixing unit, the fuser membrane is one at faulty no wonder double images therefore change the fuser membrane the problem is gone. the fixing unit is where the copy paper pass and the pressure roller together with the membrane enables the image to be permanent on paper, sometimes you just need to clean the rollers using silicon oil i.e. the pressure roller and the membrane.
