20 Most Recent
Canon NP 6545 Copier Questions & Answers
E002 error
Symptom
E000/002/003/261/733 may occur when connecting the machine with power source having much noise, such
as a private power generator
<Cause>
The power line noise prevents the normal operation of zero cross signals, causing poor control of power supply
to the fixing heater.
<Factory Measures>
New type of switching regulator PCB is used to decrease the effect of power line noise.
try to change Switching Regulator PCB (FH3-2614-020 ) ..old-FH3-2614-000
Check version of system software iR3300 Ver.11.01
1)Countermeasure for E002
2)Modification of the temperature adjustment control for free
size paper
3)Multi-purpose tray for B6 size (out of specification)
supported
4)Modification of the problem for the service mode
(REGIST) performance
5)Modification of the problem for the service mode (TRYSTP)
performance
E005 canon np6545
A E005 means that the fuser cleaning web needs to be replaced. Also, after you replace the web, you need to reset the web counter in service mode. Also, it is a good thing to check the waste toner bottle at the same time... Good Luck
Canon NP6545 Error 0005, please
this is error for fixing web cleaning belt.call service for exchange of web.
BUT THIS IS OLD MODEL AND MAYBE THER ISN'T SPARE PARTS AVAILBLE ANYMORE.
THIS ERROR CAN BE RESETED IN SERVICE MODE, BUT IT IS COMPLICATED FOR YOU.(BECAUSE OF SERVICE TOOLS AND SKILLS )
